![]() | Home > Technical > Jacking |
IIRC Booby posted this last year so you might find something in his gallery 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks I'll have a look.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
If you try to jack off chassis you will probably find must jacks will not go high enough. Jack off the wishbone, there is an indentation which should locate the jack ok.
Thanks
Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49 ![]() ![]() |
I use a 3 ton trolley jack, and have substituted the removable cup for a custom made plate (an engineering company turned it up for me for a few pounds), that has a locating peg, that locates in one of the four jacking points on the chassis, so it cannot slip. I have faced the plate with a piece of leather, so it won't scratch the chassis when lifting.
Thanks that sounds interesting...have you a pic?
Here is a photo;
Thanks Mike
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Not sure on the size of the hole/peg but would a large size bolt mounted from the underside of a flat plate do the same jog of locating the jack lifting point. |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
I do mine like this
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
Panda - I done the exact same thing!
Not all of us have a forklift |
