Home > Technical > Jacking
mse
Jacking
Whats the best place to jack up the sport with a proper trolley chack...i was thinking just behind the wishbone on the chassis section? Mike
2014 Facelift Discovery
Post #297023 Fri Apr 22 2011 3:35pm
Tim in Scotland
IIRC Booby posted this last year so you might find something in his gallery 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #297025 Fri Apr 22 2011 3:50pm
mse
Thanks I'll have a look.
Different to previous lrs and cars so I dont want to screw it up! Mike
Post #297037 Fri Apr 22 2011 7:46pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
If you try to jack off chassis you will probably find must jacks will not go high enough. Jack off the wishbone, there is an indentation which should locate the jack ok.
Landrovers advice is to jack off designated points under chassis but provide a unstable sissor jack and lots of people have confused rear nearside point with air compressor cover which has then been damaged.
Post #297039 Fri Apr 22 2011 8:24pm
mse
Thanks
Jack wise I have proper pro 3 ton jacks and stands...but I guessed there was plenty more to consider than a discovery Mike
Post #297047 Fri Apr 22 2011 8:50pm
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
I use a 3 ton trolley jack, and have substituted the removable cup for a custom made plate (an engineering company turned it up for me for a few pounds), that has a locating peg, that locates in one of the four jacking points on the chassis, so it cannot slip. I have faced the plate with a piece of leather, so it won't scratch the chassis when lifting.
Hope this helps.
Bob.
Post #297104 Sat Apr 23 2011 3:20pm
mse
Thanks that sounds interesting...have you a pic?
I have some custom pads for the cup...but i would be interested in your solution! Mike
Post #297115 Sat Apr 23 2011 6:12pm
Bob
Here is a photo;
http://www.rrsport.co.uk/gallery/displayim...&pos=0
The white bit is the custom plate, the black disc on to is thick leather.
The disc is 90mm overall diameter, stepping down to 60mm (with the leather on), with a 14mm pin to fit in the 15mm locating hole in the chassis.
Underneath the plate is a 30mm diameter pin, 35mm long, to fit in the hole in the jack, where the original cup fit.
Hope this helps.
Bob.
Post #297121 Sat Apr 23 2011 6:39pm
mse
Thanks Mike
Post #297128 Sat Apr 23 2011 7:01pm
Supacat
Not sure on the size of the hole/peg but would a large size bolt mounted from the underside of a flat plate do the same jog of locating the jack lifting point.
Post #298410 Sat May 07 2011 7:20am
panda
I do mine like this
Post #298413 Sat May 07 2011 7:37am
big pimp
Panda - I done the exact same thing!
My forklift is only a wee 3 wheeled Toyota electric though! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #298570 Sun May 08 2011 9:05am
mse
Not all of us have a forklift Big Cry Mike
Post #298581 Sun May 08 2011 10:53am
