![]() | Home > Technical > 2 Stroke Oil added to diesel |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Sounds interesting is this on the TDV6, can you elaborate a bit more please as i have not heard anything about this or point me in the direction of the original thread |
RRS_TT Member Since: 30 Apr 2009 Location: Port of Spain Posts: 15 ![]() ![]() ![]() |
check here http://www.rrsport.co.uk/forum/topic10453-30.html Beautiful Today was the Tommorow you worried about Yesterday |
Gotta be worth a try in my TDV6 RRS then |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Mine is a basic TDV6 S, I would recommend you give it a go, the difference is amazing, having read all the previous threads in detail and other research on the web it all seems to make perfect sense. Basically the modern diesel fuels have been over refined to reduce emmissions and all you are doing is adding additional lubrication which can only help with friction and wear and tear and it also reduces soot. When you put your foot down it used to kick out smoke and now it never does! Let me know how you get on. |
8 CDC Member Since: 21 Apr 2010 Location: Sth Lanarkshire Posts: 59 ![]() ![]() ![]() |
Having read a great deal about this....on here & elsewhere, I am going to give it a go!! Currently have a quite a smokey V6, a fair rattle cold, not the most responisve in the world and only getting around 23mpg with mixed driving.
yogibear Member Since: 28 Nov 2009 Location: wolverhampton Posts: 43 ![]() ![]() ![]() |
this looks good and was going to give it a try but need some help.
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
According to Yamaha-fan on the fl2 site, the oil should be FC rated semisyntetic
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 ![]() ![]() ![]() |
I have read through the entire thread started by Yamaha-Fan on the FL2 site, she sure seems to know her stuff!!
Rislar Member Since: 04 Oct 2010 Location: Western Lake District Posts: 194 ![]() ![]() |
Good info Jim ![]() MY 18, Autobiography MY 05, 07, 10, |
Hi Rislar
Hi Yogibear, I have been using the Carlube 2-Stroke Motorcycle Oil XL, it conforms to the JASO FB standard that is suggested..
Well..have to say...I'm only doing 250ml per tank & half a tank down - all is good!! Far quieter, far smoother. Can't comment on mpg with the driving over the last couple of dauys...but if you are worried about mpg - you shouldn't have an RRS.
Melbop Member Since: 01 Nov 2010 Location: Sleaford Lincolnshire Posts: 46 ![]() ![]() ![]() |
Hi
Warren G Member Since: 09 Mar 2010 Location: Herts Posts: 98 ![]() |
Done it this week, superb, works a treat. Engine noise reduction amazing. MPG better. DING DONG. |
