Home > Technical > 2 Stroke Oil added to diesel
Page 1 of 3 123>
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I thought I would post my results from adding 300ml of 2-Stroke Oil into a tank of diesel. I had a problem with a lazy egr valve causing the engine management light to come on, having read about adding 2-Stroke oil I thought I would give it a go. I am now on my second tank and the results are amazing, the egr valve fault seems to have dissapeared, the engine is quieter, smoother, and more responsive. Before the addition I was getting 24.5mpg now it is more like 28mpg quite some improvement. Thumbs Up to the RRSport Forum!
Post #280472 Wed Nov 17 2010 12:58pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Sounds interesting is this on the TDV6, can you elaborate a bit more please as i have not heard anything about this or point me in the direction of the original thread
Post #280479 Wed Nov 17 2010 4:42pm
RRS_TT
Trinidad And Tobago 2006 Range Rover Sport TDV6 HSE Java Black
check here http://www.rrsport.co.uk/forum/topic10453-30.html Beautiful Today was the Tommorow you worried about Yesterday
Post #280480 Wed Nov 17 2010 4:47pm
chris mc
Gotta be worth a try in my TDV6 RRS then
Post #280482 Wed Nov 17 2010 4:59pm
1JBS
Mine is a basic TDV6 S, I would recommend you give it a go, the difference is amazing, having read all the previous threads in detail and other research on the web it all seems to make perfect sense. Basically the modern diesel fuels have been over refined to reduce emmissions and all you are doing is adding additional lubrication which can only help with friction and wear and tear and it also reduces soot. When you put your foot down it used to kick out smoke and now it never does! Let me know how you get on. Java Black
Post #280513 Wed Nov 17 2010 9:11pm
8 CDC
Scotland 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Having read a great deal about this....on here & elsewhere, I am going to give it a go!! Currently have a quite a smokey V6, a fair rattle cold, not the most responisve in the world and only getting around 23mpg with mixed driving.
Armed myself with a relatively good oil, a few measuring bottles & will trial the next 4 tanks over a 3 week period.
Will keep you all posted on this & also the repair bill costs........ Whistle Everybody is clinging on to their sanity….Some just hide it better than others….
Post #281027 Wed Nov 24 2010 10:33am
yogibear
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
this looks good and was going to give it a try but need some help.
i have some of this, http://www.carlube.co.uk/index.cfm?product...le=Carlube 2 Stroke
itis FB rated but i dont know if this is syinthetic or mineral as it says nothing on the bottle?
does any one know?
fraser
Post #281129 Thu Nov 25 2010 8:51pm
flydive
According to Yamaha-fan on the fl2 site, the oil should be FC rated semisyntetic
Long thread over there
http://www.freel2.com/forum/topic878.html '08 RRS TDV8
Post #281131 Thu Nov 25 2010 9:06pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
I have read through the entire thread started by Yamaha-Fan on the FL2 site, she sure seems to know her stuff!!
Anyway I decided to give it a try on my 2008 RRS (22,000 miles and still under warranty) and although its early days the engine noise from cold is much quieter and it seems generally quieter to drive at all times.
I was engouraged to use it more from the lubrication properties it adds to the standard diesel fuel. I cannot comment on any added improvements to fuel economy as I am on my first tank but as I do mostly short runs I do not expect to see any benefits worth mentioning.
I beleive it was mentioned that "FB" or above is suitable for vehicles without "DPF" and "FC" for vehicles with "DPF".
I purchased my 2T oil from Screwfix, its Semi- Synthetic "FC" and cost £4.49 ltr.
The mix should be 1:200 which is approx 400ml for a full tank.
Jim
Post #281164 Fri Nov 26 2010 10:00am
Rislar
Jim
Good info Jim Very Happy is this the stuff? LINKY If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #281165 Fri Nov 26 2010 10:09am
JimboTD5
Hi Rislar
Thats the one, Ryobi 2 Stroke. Thumbs Up
Jim
Post #281170 Fri Nov 26 2010 11:55am
1JBS
Hi Yogibear, I have been using the Carlube 2-Stroke Motorcycle Oil XL, it conforms to the JASO FB standard that is suggested..
I look forward to hearing how you get on, my car is definately much smoother and kicks out no smoke at all. Very Happy
Post #281173 Fri Nov 26 2010 1:14pm
8 CDC
Well..have to say...I'm only doing 250ml per tank & half a tank down - all is good!! Far quieter, far smoother. Can't comment on mpg with the driving over the last couple of dauys...but if you are worried about mpg - you shouldn't have an RRS.
Oh... And zero smoke what so ever when you need to get the foot down. Wasn't heard of 150 miles ago!! Everybody is clinging on to their sanity….Some just hide it better than others….
Post #281193 Fri Nov 26 2010 7:46pm
Melbop
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Hi
I'm also armed and ready to give it a go.
Iv just changed my 57 tdv8 for a 59 tdv8 with 9k on the clock.
I'm going to use comma 2 stroke oil with all the bits.
As I only do short trips this time of the year, it will be a while before I report back.
Post #281257 Sat Nov 27 2010 7:57pm
Warren G
Done it this week, superb, works a treat. Engine noise reduction amazing. MPG better. DING DONG.
Post #281303 Sun Nov 28 2010 11:58am
Page 1 of 3 123>
