Home > Technical > HDC System Error - Possibly Battery Related ? |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 |
New battery needed. No amount of charging it will help. Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne. |
Fri Oct 22 2010 11:25am |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
i would check the upper tailgate switch to see if its corroded first before replacing your battery as this could be the cause of your battery problem no point in buying a new battery if its going to die again |
Fri Oct 22 2010 2:09pm |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
Hi baxc
Sat Oct 23 2010 7:17am |
pull the rubber seal off the upper tailgate switch if you get a small flat screwdriver into one corner and prise out then just pull the rest of it off if you have the dreaded corrosion this could be the cause of your battery dying |
Sat Oct 23 2010 8:16am |
gavinohare Member Since: 20 Feb 2010 Location: Newtownabbey Posts: 2 |
I had this problem last year, when I got the battery metered it was just slightly low. I was getting hdc and terrain response faults. I had it in with the dealer and they changed sensors and checked wheel alignment??? In the end it was the battery. |
Tue Nov 02 2010 8:16pm |
jetblasters Member Since: 09 Oct 2007 Location: Heathrow Posts: 31 |
I had this.
Fri Nov 19 2010 10:58pm |
Rislar Member Since: 04 Oct 2010 Location: Western Lake District Posts: 194 |
Mine also, ended up with a new alternator as it was charging intermittently If it aint broke leave it!
Fri Nov 19 2010 11:49pm |
I have noticed that the problem doesnt seem to get any worse. If i leave the RRS for a week it will still start fine and the message appears then goes off within a second.
Sat Nov 20 2010 11:19am |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
Is this not a powersave feature? |
Sat Nov 20 2010 1:20pm |
plasterman Member Since: 03 Nov 2010 Location: staffordshire Posts: 65 |
I now have these problems with mine[all the lights on hdc failure park brake failure] i did notice that the front suspension had dropped over night and when started the vehicle rose up and also it seemed a bit hesitant to start tonight as i was driving it the sat nav was flashing and the gearbox wouldn t change up from first in auto and command mode.Do you think that this is battery related????Thanks 2007 HSE in black with 22 inch id ones with privacy glass.
Sun Jan 02 2011 10:37pm |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 |
[quote="plasterman"]I now have these problems with mine[all the lights on hdc failure park brake failure] i did notice that the front suspension had dropped over night and when started the vehicle rose up and also it seemed a bit hesitant to start tonight as |
Mon Jan 03 2011 4:59pm |
I have started it up this afternoon after i went out in it last night,it seemed a bit slow at starting,various error messages flashed before my eyes,the sat nav display was flashing on and off,and it wouldn t rise to normal suspension height.I then left it running on the drive a while,turned it off locked it re-opened it again started it and the suspension raised up to normal.I have taken it out on a run and hopefully that has put it right.Over the xmas period it has only been on short runs with all the seat heaters on,lights and so forth,so i think it was prob that lot what has killed the battery.It is going in to be checked out on wednesday so hopefully it will probably need a new battery[fingers crossed] 2007 HSE in black with 22 inch id ones with privacy glass.
Mon Jan 03 2011 5:28pm |
Just one more thing will all these error messages be stored in the computer,and am i best getting them cleared,and will an independent garage be able to do it?
Mon Jan 03 2011 5:34pm |
