Home > General > Shaking headlamps |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
It's normal.......I thought it was a RR exclusive, but my Audi also does it
Mon Sep 27 2010 7:08pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Mine shake too Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Mon Sep 27 2010 7:39pm |
wullie Member Since: 27 Mar 2009 Location: Ayrshire Posts: 81 |
Cheers Wonka, mines doesn't have the active headlamps that turn when cornering, headlamp units must be made in China Anybody else with the same?? Has anybody been to the stealers with this prob??
Mon Sep 27 2010 7:44pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
yeh, mine does it when bouncing in and out one of our many potholed roads!!, my lights were actually set for a lhd car, only found this out when i took it to france in the summer, they are basically held in by clips, and very basic plastic pins sitting in rubber grommits, i dont think they can be tightened!
Mon Sep 27 2010 10:04pm |
I think you will find all RRS have this trait, my FFRR has it too, it's all part of having self leveling BiXenon lamps rather than adaptives - my FFRR doesn't have adaptives same for my first RRS but my second RRS did have them, all of them do the same thing, but the cars with adaptives also do a nice little dance every so often too when they do a self check. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Sep 27 2010 10:08pm |
tim,
Tue Sep 28 2010 5:25am |
You mean you don't have adaptive headlamps (AFS). You have bi-xenon headlamps that also includes the dynamic headlamp leveling system. The bi-xenon module within the headlamp is controlled by actuator motors which rotate the projector module on its vertical axis to adjust the beam output. (No horizontal adjustments because there is no AFS). Thus the bi-xenon module is "loose" and flexible, subject to little movements when you go over uneven surfaces etc. Don't worry. The little dance that Tim has mentioned is actually the Initialisation Procedure which ensures that the headlamps are correctly aligned on both their vertical and horizontal axes. The headlamp leveling initialisation takes less than 3 seconds to complete. The headlamp leveling motors are powered from their current position, which can be either the upper or lower limit or somewhere in between, to their lower position and then back to the 0 degrees position. The AFS swivel initialisation starts less than 1 second after the headlamp leveling initialisation is activated to ensure that the headlamps are at or below the 0 degree position in the vertical axis, thus preventing glare to oncoming vehicles. The AFS swivel initialisation is completed in less than 2.5 seconds. The LH and RH AFS actuator motors are powered from the 0 degree position to their fully inboard position, then to their fully outboard position and then back to the 0 degree position. Hope the above explains. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Tue Sep 28 2010 6:39am |
bobby,
Tue Sep 28 2010 7:14am |
codfather, no, I do not mean what wullie is experiencing is the self-levelling check. What I meant was that with this self-levelling check feature, the bi-xenon module is not rigidly fixed, more like sitting on springs and being "bouncy" (for want of a better description!). Any small bumps "shakes" it and you see some flicker.
Tue Sep 28 2010 7:42am |
i stand corrected!
Tue Sep 28 2010 8:08am |
Malaysia Boleh!
Tue Sep 28 2010 10:33am |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Oh Bobby where would we be without you
Tue Sep 28 2010 12:24pm |
Thanks for ALL the help and info guys, so theres nothing wrong with my lamp units it's just the design. Always get the answer on this site cheers.
Tue Sep 28 2010 2:46pm |
