Home > General > Shaking headlamps
wullie
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Shaking headlamps
I have owned my RR Sport for 7 weeks now, Smile 2010, 10reg, White TDV6 3.0 ltr HSE white/colour coded bottom plastics and love it even more than the rest but for one thing, when travelling over most 'A' roads with the usual holes and stuff I have noticed that both the headlamp beams shake about like a loose bulb or poss; loose reflectors, It's ok on smooth roads well thats if you can find one.
Has any other owners of the face lift Sport noticed this???
Thanks
Wullie Cool
Post #276762 Mon Sep 27 2010 7:01pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
It's normal.......I thought it was a RR exclusive, but my Audi also does it Big Cry Big Cry
I think its something to do with the adaptive cornering or something L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #276763 Mon Sep 27 2010 7:08pm
muddywheels
Milk Float Man
Mine shake too Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #276764 Mon Sep 27 2010 7:39pm
wullie
Cheers Wonka, mines doesn't have the active headlamps that turn when cornering, headlamp units must be made in China Big Cry Anybody else with the same?? Whistle Has anybody been to the stealers with this prob??
Wullie
Post #276765 Mon Sep 27 2010 7:44pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
yeh, mine does it when bouncing in and out one of our many potholed roads!!, my lights were actually set for a lhd car, only found this out when i took it to france in the summer, they are basically held in by clips, and very basic plastic pins sitting in rubber grommits, i dont think they can be tightened!
cheers
dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #276778 Mon Sep 27 2010 10:04pm
Tim in Scotland
I think you will find all RRS have this trait, my FFRR has it too, it's all part of having self leveling BiXenon lamps rather than adaptives - my FFRR doesn't have adaptives same for my first RRS but my second RRS did have them, all of them do the same thing, but the cars with adaptives also do a nice little dance every so often too when they do a self check. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #276779 Mon Sep 27 2010 10:08pm
codfather
tim,
its more of a shoogle when you hit a bump, i dont think it is trying to re-level itself. the my10s lights are just not as secure in place or maybe the rubber grommits offer too much movement for the locating pins??
cheers
Post #276791 Tue Sep 28 2010 5:25am
Bobby
wullie wrote:
.. mines doesn't have the active headlamps that turn when cornering..Wullie
You mean you don't have adaptive headlamps (AFS).
You have bi-xenon headlamps that also includes the dynamic headlamp leveling system. The bi-xenon module within the headlamp is controlled by actuator motors which rotate the projector module on its vertical axis to adjust the beam output. (No horizontal adjustments because there is no AFS). Thus the bi-xenon module is "loose" and flexible, subject to little movements when you go over uneven surfaces etc. Don't worry.
The little dance that Tim has mentioned is actually the Initialisation Procedure which ensures that the headlamps are correctly aligned on both their vertical and horizontal axes.
The headlamp leveling initialisation takes less than 3 seconds to complete. The headlamp leveling motors are powered from their current position, which can be either the upper or lower limit or somewhere in between, to their lower position and then back to the 0 degrees position.
The AFS swivel initialisation starts less than 1 second after the headlamp leveling initialisation is activated to ensure that the headlamps are at or below the 0 degree position in the vertical axis, thus preventing glare to oncoming vehicles. The AFS swivel initialisation is completed in less than 2.5 seconds. The LH and RH AFS actuator motors are powered from the 0 degree position to their fully inboard position, then to their fully outboard position and then back to the 0 degree position.
Hope the above explains. Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #276795 Tue Sep 28 2010 6:39am
codfather
bobby,
far be it for me to disagree with you, but i know exactly what wullie means with the lights, it is not doing a self levelling check, my wifes mini does this and it is very smooth for the first couple of seconds when you switch the car on, this is more of a flicker, like a loose connection when you hit a bump!
cheers
Post #276800 Tue Sep 28 2010 7:14am
Bobby
codfather, no, I do not mean what wullie is experiencing is the self-levelling check. What I meant was that with this self-levelling check feature, the bi-xenon module is not rigidly fixed, more like sitting on springs and being "bouncy" (for want of a better description!). Any small bumps "shakes" it and you see some flicker. Smile
I get it all the time. Laughing Malaysia Boleh!
Post #276804 Tue Sep 28 2010 7:42am
codfather
i stand corrected! Thumbs Up
cheers
Post #276809 Tue Sep 28 2010 8:08am
Bobby
Thumbs Up Malaysia Boleh!
Post #276823 Tue Sep 28 2010 10:33am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Oh Bobby where would we be without you Bow down Bow down
My Lexus had the same adaptive headlamps and yes the dancing on start up is the same and they also flickered when going over bumps
Post #276834 Tue Sep 28 2010 12:24pm
wullie
Thanks for ALL the help and info guys, so theres nothing wrong with my lamp units it's just the design. Always get the answer on this site cheers.
Wullie Thumbs Up
Post #276842 Tue Sep 28 2010 2:46pm
