![]() | Home > General > Shaking headlamps |
It's normal.......I thought it was a RR exclusive, but my Audi also does it |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
Mine shake too |
wullie Member Since: 28 Mar 2009 Location: Ayrshire Posts: 81 ![]() ![]() ![]() |
Cheers Wonka, mines doesn't have the active headlamps that turn when cornering, headlamp units must be made in China |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
yeh, mine does it when bouncing in and out one of our many potholed roads!!, my lights were actually set for a lhd car, only found this out when i took it to france in the summer, they are basically held in by clips, and very basic plastic pins sitting in rubber grommits, i dont think they can be tightened!
I think you will find all RRS have this trait, my FFRR has it too, it's all part of having self leveling BiXenon lamps rather than adaptives - my FFRR doesn't have adaptives same for my first RRS but my second RRS did have them, all of them do the same thing, but the cars with adaptives also do a nice little dance every so often too when they do a self check. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
tim,
You mean you don't have adaptive headlamps (AFS). You have bi-xenon headlamps that also includes the dynamic headlamp leveling system. The bi-xenon module within the headlamp is controlled by actuator motors which rotate the projector module on its vertical axis to adjust the beam output. (No horizontal adjustments because there is no AFS). Thus the bi-xenon module is "loose" and flexible, subject to little movements when you go over uneven surfaces etc. Don't worry. The little dance that Tim has mentioned is actually the Initialisation Procedure which ensures that the headlamps are correctly aligned on both their vertical and horizontal axes. The headlamp leveling initialisation takes less than 3 seconds to complete. The headlamp leveling motors are powered from their current position, which can be either the upper or lower limit or somewhere in between, to their lower position and then back to the 0 degrees position. The AFS swivel initialisation starts less than 1 second after the headlamp leveling initialisation is activated to ensure that the headlamps are at or below the 0 degree position in the vertical axis, thus preventing glare to oncoming vehicles. The AFS swivel initialisation is completed in less than 2.5 seconds. The LH and RH AFS actuator motors are powered from the 0 degree position to their fully inboard position, then to their fully outboard position and then back to the 0 degree position. Hope the above explains. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
bobby,
codfather, no, I do not mean what wullie is experiencing is the self-levelling check. What I meant was that with this self-levelling check feature, the bi-xenon module is not rigidly fixed, more like sitting on springs and being "bouncy" (for want of a better description!). Any small bumps "shakes" it and you see some flicker. |
i stand corrected! |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Oh Bobby where would we be without you |
Thanks for ALL the help and info guys, so theres nothing wrong with my lamp units it's just the design. Always get the answer on this site cheers.
