![]() | Home > Technical > Noisy Tailgate |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
That's complete rubbish, I have it fitted on my car. It is quite new, only last 3 or 4 months, and there's not much to it.., BUT IT DOES EXIST!!! Your lazy Dealer cant be bothered to do his research! Umbertob will put it right, he's really clued-up! Let us know the outcome, fingers crossed! ![]() |
Worth a small donation to the site? |
Smiffy Member Since: 24 Dec 2006 Location: Northamptonshire Posts: 8 ![]() ![]() ![]() |
Just thought I would add my thanks to Brian for pointing me in the right direction in terms of his rattly tailgate solution. It may help other sufferers to know that due to a lack of Velcro in my garage, I applied a slightly different solution which has worked equally well.
afewbeers Member Since: 02 Mar 2008 Location: here and there Posts: 21 ![]() ![]() ![]() |
A big thanks for this tip, it used to really irritate me but with all the other problems I've had with the car I felt a bit embarrassed to moan about a bit of a rattle from the tailgate. |
Beasty Member Since: 04 Sep 2010 Location: Down South Posts: 3 ![]() ![]() ![]() |
A big thanks from me too for this info. It has got rid of the worst bit of the noise from my rear |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
Could somebody please forward me the TSB for the LATCH REPAIR KIT?
Skywalker, sorry I could not find anything in Spanish! |
Cheers Bobby! |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
Hi guys, my RRS has been to a dealer recently to fix the tailgate upper section as it would not close properly. Now it has been fixed, a new latch was installed and now I have exact the same problem. Absolutely gutted, as suspension noise has just been fixed and now there is a new noise... Will have a look at it later today, and probably will have to take it back to LPR. Vadim A. |
So it checked the tailgate just as the TSB LTB00006V2 says, and the striker loop ha no black coating. Since the new latch was installed by LPR it makes the metallic rattle noise... I will be taking it back for the fix. Damn it! |
bradtarga34 Member Since: 19 Jan 2010 Location: Walton-on-Thames Posts: 147 ![]() |
That must be really disappointing, especially as LPR are regarded as one of the best there is for looking after our pride and joys... On the plus side, I bet you are enjoying the lack of noise from the front end! |
Oh no, don't get me wrong, I am very happy with the service at LRP. Although the tailgate problem appeared after installing the new latch, which obviously was necessary and the actual problem affects random cars, there is no way they could have known my car would be affected. So no hard feelings there, I still will come back to them and will recommend them to a friend. Vadim A. |
Finally, got my RRS to LPR. Checked the tailgate several times and realised that the plastic bit, which had to be removed to install a new latch into the upper tailgate section, was not installed back properly and there was a big gap between the plastic cover and the actual door itself, as if the cover did not align with the door properly. Also, I noticed a small damage to the plastic cover right where the gap is at its biggest. My RRS is 6 months old and I know it inch by inch and I know the gap was not there, but appeared after installing the new latch.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
To fix the tail gate rattle do the following:
