Home > Technical > Noisy Tailgate |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Before I book-in my RRS for its' weekly warranty repair, can anybody please tell me if the tailgate is supposed to rattle and squeek on road bumps and speedhumps? Is it in need of a simple adjustment, or is this just another of the many "live-with-it" characteristics? I know Ford own Range Rover but is it really meant to sound like a Transit van??? |
Tue Jan 23 2007 9:05pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Yeah RRUK had this problem! RRS TDV6 Gone but still around
Tue Jan 23 2007 10:47pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Could be this one, TSB # LS501-013
Wed Jan 24 2007 12:00am |
Peter Member Since: 28 Feb 2006 Location: Maidenhead Posts: 175 |
My RRS TDV6 HSE went back to the stealer (Stratstone High Wycombe) in November for a 15 point fix list including some software mods.
Sat Jan 27 2007 10:36am |
Thanks fellas. I managed to locate RRUK's previous post and followed the "open upper glass section and lean on lower tailgate" advice. Sure enough, there's a lot squeaking and plastic rubbing going on. However, when it happens on the road at speehumps, for instance, it's accompanied by a distinct knock or thud plus a metallic rattle. Looks like a number of things are contributing? Car back in garage Monday (as it is most weeks).., watch this space!!! |
Sat Jan 27 2007 2:19pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
Brian, as Peter mentioned above, the service fix for a tailgate rattle as you have described is the plastic sheath on the latch bar. This is to reduce or eliminate any freeplay in the latch mechanism.
Sat Jan 27 2007 9:23pm |
Thanks TB. I'll update after it's back from the Main Stealer next week. Be interesting to hear their diagnosis and, more importantly, if it actually fixes the annoying problem. |
Sun Jan 28 2007 5:04am |
Hi TB, we haven't chatted for a while! You ok?
Sun Jan 28 2007 8:04pm |
Peter, the black plastic fix has been around since well before Christmas. I had the rattle on my tailgate, so was in the perfect place to get it fixed.
Sun Jan 28 2007 9:38pm |
You're dead right TB. Just collected the car after 4 days and they've obtained and fitted a recently released tailgate rattle repair kit. However, the bad news is the noise still appears present. |
Thu Feb 01 2007 11:48am |
Well, it's not the tailgate latch that's rattling then.
Thu Feb 01 2007 8:26pm |
Cheers TB. I've got to go back tomorrow as I discovered they've f ked an alloy, so I'll break the bad news and mention your suggestion. |
Thu Feb 01 2007 8:33pm |
Right. When I first had the tailgate noise, it was a combination of a metallic rattle, plastic squeak and a thud on speedhumps. The repair kit seems to have cured the metallic rattle. Today the dealer adjusted the 4 rubber buffers and that appears to have stopped the thump.
Fri Feb 02 2007 3:08pm |
Brian - a photo please! 2005 Zambezi TDV6 - Gone but not forgotten
Fri Feb 02 2007 3:22pm |
