![]() | Home > Technical > Noisy Tailgate |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Ok........... so ebay tyres were a bad choice ! |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Still on the case then MDP? |
Peter Member Since: 28 Feb 2006 Location: Maidenhead Posts: 175 ![]() ![]() ![]() |
Remoulds? Never trust 'em!
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
just getting back on track for a second, I too have stuck on the fuzzy velcro pads on the tailgate as shown by Brian, even though I will only have the car for another week or 2, it seemed worth it, I'm just about to go out in it but I tried pushing down on the lower tailgate and the squeak had gone.... |
That's great news RRUK, and, as you know, I had exactly the same problem as you. A plastic "creak" when leaning on the closed lower tailgate, noticeable on speedhumps, but gone with the velcro pads! Dont forget to also adjust the 4 rubber stops, that helped stop the annoying "thump". Yep, looks like the combined forces of RRSport have struck again!!! Thanks. ![]() |
Would you believe it - after the great FREEZE & THAW , my tailgate has become very ratly |
You may find the "metallic rattle" will require the LR tailgate latch repair kit, which I had done to mine. However, if it's an irritating noisy plasticy creak, then the Velcro fluffy pads should cure it. Good luck mate. |
I'm going to do this fix (Velcro) on mine today.
Peter, this "tailgate latch repair kit" is a new item and fixes the upper glass section, not the main lower tailgate lock. My Dealer obtained it in 2 days last week so must be in stock. Also, as it worked, it must be a known common fault.
Well as promised I applied sticky backed velcro to my tailgate as described here previously. With great anticipation, I then opened the glass section and put my weight onto the sill of the tailgate and awaited the squeak but hey, it seems to have gone!! As the kids are not at school this week I haven't tried it on the 17 speedhumps to school route yet so can't report if it has truly repaired the rattle / bump /sqeak from the tailgate that I have suffered for 10 months but the other road here that makes the tailgate make a noise somethimes is deathly silent following the old Velcro trick on Sunday. I'll keep you posted! It's finally gone! Replaced with BMW 730SE in Sophisto grey Xirallic finish with Oyster (Ivory) and black interior. DAB, Climate glass, Ceramic iDrive and gear selector, power boot and iPhone Bluetooth pack - luvvin' it! I miss my old RRS "bucket" rattling around but it just had to go! Last edited by Peter on Wed Feb 14 2007 5:42am. Edited 1 time in total |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Cool good stuff |
