![]() | Home > Technical > battery drain |
Did you read THIS? Malaysia Boleh!
tiggybelle Member Since: 27 Jul 2010 Location: united kingdom Posts: 26 ![]() ![]() |
yep checked the VIN and not within that catagory... just seems strange that i have only hade problems since the service... i had had some low battery sort of problems before once when driving all lights went out and all the interior equipment switched off eg cd and sat nave screen and dash lights ... stopped and restarted and was fine but range rover did a check and just said ooh it can happen... doesnt really make me feel confident about anything so i thought id have a browse here |
alfacat Member Since: 05 Mar 2010 Location: suffolk Posts: 5 ![]() ![]() ![]() |
hi
Ooh that is on my list of things to try as I'd seen it mentioned on another site and my tailgate had been sticking |
hi,
Right when the rain has stopped I'll go and have a look |
Right guess what?!!! Just popped out to check tailgate and battery is so flat it won't even let me open the side door manually after popping the keyhole cover off!!!! So can't even open bonnet to jumpstart it!!! Looks like another call out and that's going to cost again |
Get an auto electrician (mainly because I don't know where it is but Bobby might!) and check the car's earthing/ grounding, somebody reported this to be a cause of their battery maladies earlier this year IIRC 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
im crying now!!!!! |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
hi m8 i had the same problem with the battery took me 3 weeks of testing to find it was the upper tailgate switch take the rubber seal off the switch if the switch is corroded inside that is your problem |
Hi:) thanks for that I'm going to get a man to have a look tomorrow had land rover assistance put as I couldn't get in the car because app the manual lock does deadlock when battery flat!!!! Anyway I asked him about the seal and he said it would flash on dash tailgate open if there was a problem but I did find out that the upper tailgate is stuck shut!!! Havent used it for a while oops |
mine didnt say tailgate open because the part had corroded it stops the tailgate from opening but when you take the rubber seal of the catch you can simply push the switch in with a pin and it will open you also dont need to get in the car to do this let us know how you get on today m8 |
heya! well the man peeled of the rubber seal and the switch came out as powder!!!! having it replaced today so we will se if that has been the problem it looks highly likely!! im just so blimmin annoyed that it was me that had to spend ages trying to find the problem and when i did mention that it could be the switch they still didnt look untill i sent all the replies on here to them telling them how to do it !!!! ooh men |
glad you sorted it took me 3 weeks of searching and testing plus new battery to find the problem |
