Home > Technical > battery drain |
Did you read THIS? Malaysia Boleh!
Tue Jul 27 2010 11:52am |
tiggybelle Member Since: 27 Jul 2010 Location: united kingdom Posts: 26 |
yep checked the VIN and not within that catagory... just seems strange that i have only hade problems since the service... i had had some low battery sort of problems before once when driving all lights went out and all the interior equipment switched off eg cd and sat nave screen and dash lights ... stopped and restarted and was fine but range rover did a check and just said ooh it can happen... doesnt really make me feel confident about anything so i thought id have a browse here |
Tue Jul 27 2010 12:14pm |
alfacat Member Since: 05 Mar 2010 Location: suffolk Posts: 5 |
hi
Tue Jul 27 2010 1:23pm |
Ooh that is on my list of things to try as I'd seen it mentioned on another site and my tailgate had been sticking how do I check for corrosion though (doh) the tailgate doesn't always stick though... It's driving me mad I love the car but it's such a pain |
Tue Jul 27 2010 2:00pm |
hi,
Tue Jul 27 2010 2:13pm |
Right when the rain has stopped I'll go and have a look any more suggestions from anyone are welcome |
Tue Jul 27 2010 2:35pm |
Right guess what?!!! Just popped out to check tailgate and battery is so flat it won't even let me open the side door manually after popping the keyhole cover off!!!! So can't even open bonnet to jumpstart it!!! Looks like another call out and that's going to cost again I'm lost as to what to do |
Tue Jul 27 2010 3:12pm |
Get an auto electrician (mainly because I don't know where it is but Bobby might!) and check the car's earthing/ grounding, somebody reported this to be a cause of their battery maladies earlier this year IIRC 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Jul 27 2010 3:47pm |
im crying now!!!!! just spoke to land rover re the lock out and the land rover assist guy has said that a range rover sport when the battery is flat goes into a deadlock mode so it cant be manually unlocked??!!!!! but the land rover dealership technicians have said that it should manually unlock as it is purely mecanical and not dictated by the battery strengh... only had a new lock fitted yesterday as it had broke i was told this happens alot too probably because i have to use it so blinkin much to jump start it !!!! so whos right does anyone know ... |
Tue Jul 27 2010 4:26pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
hi m8 i had the same problem with the battery took me 3 weeks of testing to find it was the upper tailgate switch take the rubber seal off the switch if the switch is corroded inside that is your problem |
Wed Jul 28 2010 6:46pm |
Hi:) thanks for that I'm going to get a man to have a look tomorrow had land rover assistance put as I couldn't get in the car because app the manual lock does deadlock when battery flat!!!! Anyway I asked him about the seal and he said it would flash on dash tailgate open if there was a problem but I did find out that the upper tailgate is stuck shut!!! Havent used it for a while oops so it is looking like this could be the problem but he didn't know how to check it !!! And I have noooo idea so getting a guy tomorrow to look for me I will keep you informed |
Wed Jul 28 2010 8:57pm |
mine didnt say tailgate open because the part had corroded it stops the tailgate from opening but when you take the rubber seal of the catch you can simply push the switch in with a pin and it will open you also dont need to get in the car to do this let us know how you get on today m8 |
Thu Jul 29 2010 5:59am |
heya! well the man peeled of the rubber seal and the switch came out as powder!!!! having it replaced today so we will se if that has been the problem it looks highly likely!! im just so blimmin annoyed that it was me that had to spend ages trying to find the problem and when i did mention that it could be the switch they still didnt look untill i sent all the replies on here to them telling them how to do it !!!! ooh men anywhooo i will keep you informed thank you so much for all your help hopefully i will fall back in love with my beast again now though he did start clunking again yesterday when i was going round islands!! |
Fri Jul 30 2010 8:40am |
glad you sorted it took me 3 weeks of searching and testing plus new battery to find the problem |
Fri Jul 30 2010 10:22am |
