Home > Technical > TDV8 Exhaust Gasket
rasspe
United Kingdom 2007 Range Rover Sport TDV8 HSE Rimini Red
TDV8 Exhaust Gasket
Hi Guys
This is my first post, but have been using the site for reference for some time.
I have a 57 plate RRS and love it but thought I should advise others of an issue I have at present. The exhaust gasket has gone and in order to do this they have had to remove the body from the chasis. It took them 13 hours to remove the body and 5 days latter I am still waiting for its return. Aparently there has been a tech bullitin about this?
I would advise that anyone with a RRS coming out of warranty get this checked over.
The other issue was about 12 months ago the back bearing in the transfer box went. Fortunately again under warranty.
The RRS has only cover 65K miles.
Will not change away as love the car and makes me smile every time I drive it.
It anyone wishes to see it in bit I can email pics
Richard
Post #265189 Thu May 06 2010 9:03am
BAWSACK
Scotland 2008 Range Rover Sport TDV8 HSE Zermatt Silver
Holy smoke Richard! glad it was still under warranty for you. I have read this somewhere before about removing the body to gain access to the turbos etc, it would fear you having to pay to get this done!
Would love to see the pics Thumbs Up
Post #265195 Thu May 06 2010 9:51am
Endjin
Scotland
Holy Moly Shocked That does seem rather an extreme situation just to replace a gasket! Glad you are not out of pocket on this. Pics would be really interesting Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #265198 Thu May 06 2010 10:17am
rasspe
If you send me your email I will send them not sure how to put them on here
[/url]
Post #265202 Thu May 06 2010 10:31am
rasspe
Sorted gallery.
In rasspe gallery
Under RR Body Off
Wife been in to help,,, bloody computers[/img]
Post #265238 Thu May 06 2010 2:08pm
NightFox
rasspe wrote:
Sorted gallery.
In rasspe gallery
Under RR Body Off
Jeeeeeeeez!
Shocked Shocked Shocked
Not a DIY job then! Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #265262 Thu May 06 2010 4:40pm
Bob.
Re: TDV8 Exhaust Gasket
rasspe wrote:
The exhaust gasket has gone.......Aparently there has been a tech bullitin about this?
Can't find a Technical Bulletin but there is a Service Bulletin listed on GTR. Title is - Range Rover Sport 3.6 TDV8 Exhaust Manifold Reference: SSM44148 (1)
Bobby
Can you reveal the contents please.
Post #265330 Fri May 07 2010 8:56am
rasspe
Will ask the dealership when I collect it back hopefully today
10 days so far without it
Post #265343 Fri May 07 2010 10:58am
rasspe
Well guess what the dealership phoned today to say both heads are coming off and being sent to a machine shop to be drilled out and retaped.
Not happy about this surely it would have been just as cheap to fit new heads?
Meanwhile I am driving a freeloader!!!!!!!
Any advice welcome on this?
Richard
Post #265396 Sat May 08 2010 7:34am
klm
2008 Range Rover Sport TDV8 HSE Stornoway Grey
well chuffed,,,,,,,,,,,,, just been informed that mine has now got to have this done Big Cry Big Cry Big Cry
Post #267253 Thu May 27 2010 5:31pm
Sizzle TDV8
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Sorry for being stooopid..... But what's the problem with the gaskets??? Are they just a inferior material prone to failing or what???
Just hope mine don't fail as out of warranty now. 2007 RRS TDV8 Stornaway Grey with lots of smiles..
2007 Audi A4 2.0T Cabriolet
Missing - 2008 Suzuki GSX-R 750
Post #267381 Fri May 28 2010 11:45pm
Bob.
It's not the gaskets, it's distorsion of the exhaust manifolds. - see below.
LS - Range Rover Sport
Title Range Rover Sport 3.6 TDV8 Exhaust Manifold
Last Modified 22-APR-2010 14:32
Category Engine
Symptom 497000 Engine Noise
Content
Issue:
The customer may complain of a whistling/blowing
noise from the engine compartment which maybe
more prominent during cold start up and, or whilst
accelerating.
Cause:
Exhaust manifold distortion.
Action:
If the above stated concern is verified please raise
an EPQR specifying the crack off torque value of the
exhaust manifold nuts. Please also retain the old
exhaust manifolds/gaskets/studs and nuts as they
maybe required for engineering investigation
purposes.
Replacement of the exhaust manifold(s) on Range
Rover Sport requires body removal. Land Rover
therefore recommend that if the above stated cause
is verified on one bank, both exhaust manifolds
should be replaced to avoid the possibility of a repeat
concern.
Parts Information
Manifold Exhaust RH – LR005685
Manifold Exhaust LH – LR005686
Exhaust Manifold Studs – 1357627
Exhaust Manifold Nuts – LR004057
Exhaust Manifold Gaskets – 1420910
Repair Operation Time
30.15.13 – Manifolds – exhaust – set – renew –
9.9hrs
Post #267393 Sat May 29 2010 10:18am
Sizzle TDV8
Thanks for the info Bob.
Is this noise prominent from inside the cabin with the windows shut?? As I can only hear a 'wooshing' noise whilst accelerating hard with the window open. BUT I thought that could be the turbos spooling up??
Anything detrimentally bad if a vehicle has these symptoms but doesn't have the rectification work carried out?? And would it be a dealer diagnosis??
Thanks in advance 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #267477 Sun May 30 2010 10:33am
Bob.
This is one problem I haven't noticed - yet! From exhaust leaks I have heard in the past I would expect that if you open the bonnet and hear a hissing/whistling noise while the engine is running at constant speed you may have an issue.
Perhaps rasspe or klm can tell us what they could hear.
Post #267479 Sun May 30 2010 11:36am
rasspe
Hi Guys
Sorry for the delay, it was like a bird chirping my wife said, yes you can easily hear it inside but is more prominent with the windows open.
I like the 9.9 hours bit mine took 3 weeks. only joking 3 and half really.
The dealer said it took 13 hours to remove the body. Warranty invoice was over £2K
It is back now, lost confidence in LR at the mo, might be parting with it for a non LR product as I cannot see an easy future with the RRS.
Have transits with less hassle and more miles and animals driving them
Richard
Post #267725 Thu Jun 03 2010 7:54am
