![]() | Home > Technical > TDV8 Exhaust Gasket |
BAWSACK Member Since: 12 Jan 2010 Location: Falkirk Posts: 18 ![]() ![]() ![]() |
Holy smoke Richard! glad it was still under warranty for you. I have read this somewhere before about removing the body to gain access to the turbos etc, it would fear you having to pay to get this done!
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Holy Moly |
rasspe Member Since: 04 May 2010 Location: Midlands Posts: 9 ![]() ![]() ![]() |
If you send me your email I will send them not sure how to put them on here
Sorted gallery.
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 ![]() ![]() |
Jeeeeeeeez! ![]() ![]() ![]() Not a DIY job then! Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+ Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE ![]() |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Can't find a Technical Bulletin but there is a Service Bulletin listed on GTR. Title is - Range Rover Sport 3.6 TDV8 Exhaust Manifold Reference: SSM44148 (1) Bobby Can you reveal the contents please. |
Will ask the dealership when I collect it back hopefully today
Well guess what the dealership phoned today to say both heads are coming off and being sent to a machine shop to be drilled out and retaped.
klm Member Since: 30 May 2006 Location: UK Posts: 155 ![]() ![]() |
well chuffed,,,,,,,,,,,,, just been informed that mine has now got to have this done |
Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117 ![]() ![]() ![]() |
Sorry for being stooopid..... But what's the problem with the gaskets??? Are they just a inferior material prone to failing or what???
It's not the gaskets, it's distorsion of the exhaust manifolds. - see below.
Thanks for the info Bob.
This is one problem I haven't noticed - yet! From exhaust leaks I have heard in the past I would expect that if you open the bonnet and hear a hissing/whistling noise while the engine is running at constant speed you may have an issue.
Hi Guys
