![]() | Home > General > have rrs's only got 5 gear's? |
kedz Member Since: 10 Apr 2009 Location: manchester Posts: 151 ![]() ![]() ![]() |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
No... What makes you ask that? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
From memory you'll only get 5 in the sport mode IIRC, in auto you get the 6th |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
You can engage 6th in manual sport mode as well...just tap the shift knob forward one more time and you can lock it in 6th. In fact, this can be used as well on downhills to prevent the transmission from downshifting to 5th on its own sometimes. PJPR Cairns Blue HSE 180k Miles of Adventure |
Sport mode will engage 6th gear above 82 mph only |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
It must vary between petrol and diesel. I can engage 6th at around 80kph (50mph) in manual mode Gone - 2008 Stornoway Grey RRS 2.7 TDV6
I'll have to try this one - i know the last (both TDV6) would not go into 6th automatically in manual mode... will try tomorrow |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 ![]() ![]() ![]() |
Last summer when I tried top speed in my S/C, my RRS shifted from 6 to 5th gear in about 210kmh and reached the top speed 225kmh with 5th gear. Is this normal? RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
6 gears - confirmed - access to the six differs between manual and auto |
cheer's guy's |
MAW and PJPR01 are both right, however, there is a difference between Sports Mode and Manual Commandshift (which PJPR01 is referring to).
[quote="Bobby"]MAW and PJPR01 are both right, however, there is a difference between Sports Mode and Manual Commandshift (which PJPR01 is referring to).
But you're still wrong about Sports Mode... It WILL use 6th above 82mph |
