![]() | Home > Technical > twin electrics help please |
Do you mean the tow electrics? 2005 Zambezi TDV6 - Gone but not forgotten
shawn Member Since: 10 Nov 2005 Location: staffordshire Posts: 21 ![]() |
Hi VA yes towbar twin electrics for my caravan cheers shawn |
Easy to fit and I think the ECU does need to be reprogrammed (I think!). Do a search this is something that has been discussed before, 2005 Zambezi TDV6 - Gone but not forgotten
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
From what i know on this - it is a self fit, ECU has to be programmed ONLY to turn rear Fogs off on the RRS when towing - to prevent rear view glare bouncing off a caravan - I only use trailers and bike racks so little impact - stealer job for ECU work if you cannot live with fog glare bouncing off the caravan .... I did my own on two RRS's...
Theo_Pental Member Since: 10 Aug 2008 Location: Notts Posts: 113 ![]() ![]() ![]() |
Im waiting for the twin N and S towing electrics too
If you are only looking to have your ECU enabled after fitting your towbar yourself then go into WH Smith and look through any of the 4 Land Rover titled magazines and have a look in the listings of independent non-franchise specialists - for the most part they have all the latest techno equipment to be able to carry out the changes to the ECU - IIRC it's called something like Testbook or Autologic, or you could contact 10forCash over on the Disco3 forums who runs a mobile fitting service.
well i have got a twin electric pack from a dealer in lincolnshire they are posting it to me so i get it tomorrow.
Ask Paul Keating the service manager at CHPR for a 4th opinion |
Paul Keating is not to be trusted
shawn
joka748 Member Since: 28 Nov 2007 Location: Hampshire Posts: 63 ![]() ![]() ![]() |
I fitted LR twin electrics myself, no ECU change and have had no problems with parking sensors.
wullie Member Since: 27 Mar 2009 Location: Ayrshire Posts: 81 ![]() ![]() ![]() |
Hi Shawn
As posted above ONLY ECU impact is fogs on RRS - turned off when electrics connected to stop rear glare off a caravan.... Rear PDC etc etc all auto sensed - the issue re the fogs may even have been ironed out on newer MY's....
Marshalls Lincoln by chance ? Was it Tim you dealt with ? |
