Home > Technical > Low power mode on radio |
SteveWilliams Member Since: 05 Aug 2007 Location: Swindon Posts: 138 |
Tim
Sun Feb 08 2009 11:24am |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
the clever electronics....
Sun Feb 08 2009 11:33am |
That's more like it!! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sun Feb 08 2009 11:57am |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
Thirded . WINNER - 2008 Best All New Photograph WINNER - 2009 Best All New Photograph |
Sun Feb 08 2009 1:18pm |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
it needs a second battery |
Sun Feb 08 2009 1:53pm |
Sun Feb 08 2009 2:51pm |
I suspect it's the clever electronics too as it goes away once the load comes off the battery................. K, I wouldn't need a 2nd battery as I would fit a hydraulic winch if I were fitting one! Lighter, smaller, more powerful, works under water unlike the lecky ones, doesn't burn out just when you need it most and doesn't need a 2nd battery and split charge system! Ok so they cost twice as much but you don't need to then pay for all the add-ons to make it work. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Feb 08 2009 4:07pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
I have dual batteries fitted and it still does the same on mine |
Sun Feb 08 2009 4:22pm |
THANK YOU lespes - that eliminates Kaine
Sun Feb 08 2009 4:53pm |
Sun Feb 08 2009 7:30pm |
richh Member Since: 15 Feb 2009 Location: england Posts: 9 |
hi guys, do your heated seats not work or go off suddenly, if so it could be one of the sensors on the engine system, when they die or are unplugged they set a default setting to keep the car running. find someone with IDS on try reading the real time outputs and you should find one of the temp. sensor thats reading 40 derees. hope this helps, richh. they all do that! |
Sun Feb 15 2009 12:00pm |
8 JTS Member Since: 26 Jan 2009 Location: Cheshire Posts: 16 |
I have had this warning, had it in with a dealer and it needs a new battery and altinator, covered under warranty |
Fri Feb 20 2009 9:20pm |
