Home > Technical > Low power mode on radio
Tim in Scotland
These cold mornings I've been running a fair bit with the heated seats and the Prog button for the heating/screen defrosters on until the car is bearably cool inside.
If I turn switch the radio on I get the LOW POWER indication on the radio display and cannot adjust the volume above 16/17. Once the car is warmed up and the heated seats are off the radio volume can be adjusted. Is my battery on the way out (it's only 15 months old) or is it just the very cold weather reducing it's efficiency and the clever electronics reducing the load on it? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210450 Sun Feb 08 2009 10:41am
SteveWilliams
Wales 2006 Range Rover Sport TDV6 HSE Rimini Red
Tim
I would say battery is most likely culprit. but the alternator might not be charging the battery properly. Only way to find out is to get it checked,
Post #210455 Sun Feb 08 2009 11:24am
the clever electronics.... Cool
Post #210457 Sun Feb 08 2009 11:33am
Bobby
That's more like it!! Wink Thumbs Up Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #210458 Sun Feb 08 2009 11:57am
ViewWise
Thirded Thumbs Up . WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #210467 Sun Feb 08 2009 1:18pm
it needs a second battery Whistle
Post #210473 Sun Feb 08 2009 1:53pm
Rolling Eyes Laughing
Post #210474 Sun Feb 08 2009 2:51pm
Tim in Scotland
I suspect it's the clever electronics too as it goes away once the load comes off the battery................. K, I wouldn't need a 2nd battery as I would fit a hydraulic winch if I were fitting one! Lighter, smaller, more powerful, works under water unlike the lecky ones, doesn't burn out just when you need it most and doesn't need a 2nd battery and split charge system! Ok so they cost twice as much but you don't need to then pay for all the add-ons to make it work. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210483 Sun Feb 08 2009 4:07pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
I have dual batteries fitted and it still does the same on mine
Post #210486 Sun Feb 08 2009 4:22pm
THANK YOU lespes - that eliminates Kaine Twisted Evil Laughing
Post #210491 Sun Feb 08 2009 4:53pm
Embarassed Laughing Laughing
Post #210512 Sun Feb 08 2009 7:30pm
richh
hi guys, do your heated seats not work or go off suddenly, if so it could be one of the sensors on the engine system, when they die or are unplugged they set a default setting to keep the car running. find someone with IDS on try reading the real time outputs and you should find one of the temp. sensor thats reading 40 derees. hope this helps, richh. they all do that!
Post #211786 Sun Feb 15 2009 12:00pm
8 JTS
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
I have had this warning, had it in with a dealer and it needs a new battery and altinator, covered under warranty Thumbs Up
Post #212898 Fri Feb 20 2009 9:20pm
