![]() | Home > Maintenance & Modifications > brembo brakes |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
I need to get mine done. standard brakes arent really up to it.
terrieremery Member Since: 07 Dec 2008 Location: devon Posts: 35 ![]() ![]() ![]() |
a set on ebay eBay Item No. 320336107984 new |
Thanks mate,
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
how easy were they to fit ? |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
2 bolts each side (tight!), to remove each caliper and bracket from the strut.
sounds simple enough, mind you brakes are one thing you dont want to get wrong - might leave it to the professionals. how do you think the stealer would feel if you rocked up with the parts and got them to fit them ? |
Prob OK on an RRS as they fit them in theory to almost any version with the dynamic pack and latterly build it into the HSE spec on all engines.
jjb218 Member Since: 22 Jul 2006 Location: Dominican Republic Posts: 94 ![]() ![]() |
I dont know the standard torque sttings for tightening this, But I have had a caliper come loose after replacing them!!!
Well the torque setting is very high (can´t remember what it is but you should find out and use the correct torque, correctly fitted these bolts do not come loose.... Cheers
DMike Member Since: 09 Nov 2007 Location: Perthshire Posts: 79 ![]() ![]() ![]() |
275Nm for caliper carriers |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 ![]() ![]() ![]() |
Mine has gone in for second service this morning (2years 20k)
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
I bet they have a load of wear left on them, get them on ebay or from LR dealer parts and change yourself or get a good independant, it will be a lot cheaper |
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 ![]() ![]() |
Whilst on the subject of Brembo brakes...has anyone noticed if there calipers have gone from black to a dirty brown....has anyone had there's resprayed. |
My calipers look great. It's the centre hubs look s**t part silver and rust |
