Home > Maintenance & Modifications > brembo brakes |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 |
I need to get mine done. standard brakes arent really up to it.
Sun Feb 01 2009 7:51pm |
terrieremery Member Since: 07 Dec 2008 Location: devon Posts: 35 |
a set on ebay eBay Item No. 320336107984 new |
Sun Feb 01 2009 8:01pm |
Thanks mate,
Tue Feb 03 2009 10:24am |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 |
how easy were they to fit ? |
Tue Feb 03 2009 11:53am |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
2 bolts each side (tight!), to remove each caliper and bracket from the strut.
Tue Feb 03 2009 2:54pm |
sounds simple enough, mind you brakes are one thing you dont want to get wrong - might leave it to the professionals. how do you think the stealer would feel if you rocked up with the parts and got them to fit them ? |
Tue Feb 03 2009 2:57pm |
Prob OK on an RRS as they fit them in theory to almost any version with the dynamic pack and latterly build it into the HSE spec on all engines.
Tue Feb 03 2009 3:01pm |
jjb218 Member Since: 22 Jul 2006 Location: Dominican Republic Posts: 94 |
I dont know the standard torque sttings for tightening this, But I have had a caliper come loose after replacing them!!!
Sat Feb 21 2009 5:56pm |
Well the torque setting is very high (can´t remember what it is but you should find out and use the correct torque, correctly fitted these bolts do not come loose.... Cheers
Sat Feb 21 2009 8:34pm |
DMike Member Since: 09 Nov 2007 Location: Perthshire Posts: 79 |
275Nm for caliper carriers |
Sun Feb 22 2009 8:55am |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
Mine has gone in for second service this morning (2years 20k)
Wed Feb 25 2009 3:06pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
I bet they have a load of wear left on them, get them on ebay or from LR dealer parts and change yourself or get a good independant, it will be a lot cheaper |
Wed Feb 25 2009 4:30pm |
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 |
Whilst on the subject of Brembo brakes...has anyone noticed if there calipers have gone from black to a dirty brown....has anyone had there's resprayed. |
Wed Feb 25 2009 8:25pm |
My calipers look great. It's the centre hubs look s**t part silver and rust
Wed Feb 25 2009 8:52pm |
