Home > Maintenance & Modifications > brembo brakes
Page 1 of 3 123>
terrieremery
England 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
brembo brakes
i fitted brembo brakes to my td6se last week all very simple got 2 calipers on ebay for �200,discs 360mm were �70 and new supercharger backplates were �17 each from landrover. they are definately better stopping and feel really good no drawbacks whatsoever they look amazing
Post #209492 Sun Feb 01 2009 8:48pm
BigMart
I need to get mine done. standard brakes arent really up to it.
Anyone know of any low cost brembos???
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #209493 Sun Feb 01 2009 8:51pm
terrieremery
a set on ebay eBay Item No. 320336107984 new
Post #209494 Sun Feb 01 2009 9:01pm
BigMart
Thanks mate,
I hadnt spotted them , I was keeping an eye out for LR breakers with an s/c.
Post #209738 Tue Feb 03 2009 11:24am
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Re: brembo brakes
how easy were they to fit ?
Post #209747 Tue Feb 03 2009 12:53pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
2 bolts each side (tight!), to remove each caliper and bracket from the strut.
Undo brake hose union at caliper.
Remove brake caliper and bracket.
1 screw and remove the brake disc
Fit new disc.
Bolt caliper to strut using same bolt holes (no bracket)
Connect brake hose and bleed.
Job done.
Apart from the hydraulics and bleeding the brakes after reconnection it is not much different to just replacing the discs...the bolts holding the brackets/Brembos to the strut have a very high torque and must be done up correctly. Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #209776 Tue Feb 03 2009 3:54pm
crowej
Fit new disc.
Job done.
sounds simple enough, mind you brakes are one thing you dont want to get wrong - might leave it to the professionals.
how do you think the stealer would feel if you rocked up with the parts and got them to fit them ?
Post #209777 Tue Feb 03 2009 3:57pm
simonsi
Prob OK on an RRS as they fit them in theory to almost any version with the dynamic pack and latterly build it into the HSE spec on all engines.
They wouldn't touch a D3 though, I had mine done by a specialist but Disco3 members have had dealers decline as the Brembo isn't fitted at all to the D3.
Still fits and works fine though... Very Happy Cheers
Simon
Post #209778 Tue Feb 03 2009 4:01pm
jjb218
2006 Range Rover Sport Supercharged Zermatt Silver
PLEASE TIGHTEN VERY GOOD!
I dont know the standard torque sttings for tightening this, But I have had a caliper come loose after replacing them!!!
Good luck!!
JJB
Post #213034 Sat Feb 21 2009 6:56pm
simonsi
Well the torque setting is very high (can�t remember what it is but you should find out and use the correct torque, correctly fitted these bolts do not come loose.... Cheers
Simon
Post #213082 Sat Feb 21 2009 9:34pm
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
275Nm for caliper carriers Thumbs Up
Post #213147 Sun Feb 22 2009 9:55am
Baron
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Mine has gone in for second service this morning (2years 20k)
Stealer just phoned told me I need new pads on the front.
�285 Big Cry  SDV8 vogue SE.
Corris grey and ivory leather + most of the toys.
Limited edition RRS model number 0001 Smile
Gone TDV8 RR Sport. Never to be forgotten.
Wife has an i8 BMW
Post #213771 Wed Feb 25 2009 4:06pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
�285 Big Cry
I bet they have a load of wear left on them, get them on ebay or from LR dealer parts and change yourself or get a good independant, it will be a lot cheaper
Post #213789 Wed Feb 25 2009 5:30pm
filaborg
Whilst on the subject of Brembo brakes...has anyone noticed if there calipers have gone from black to a dirty brown....has anyone had there's resprayed.
Post #213853 Wed Feb 25 2009 9:25pm
Baron
My calipers look great. It's the centre hubs look s**t part silver and rust Embarassed
I will have a look see how many mm's are left on the pads coming off Thumbs Up
Too bone idle these days to change them myself Big Cry Used to in the old days Whistle  SDV8 vogue SE.
Wife has an i8 BMW
Post #213857 Wed Feb 25 2009 9:52pm
Page 1 of 3 123>
