Home > Technical > DPF |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
i got it - what is your problem beside that they are inefficient and have to be exchanged to newer ones....
Fri Jan 16 2009 4:38pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
I have it on my TDV8, is standard here. No problem with it. I also had it on the TDV6, different type, it was an add-on(was already on the car) and also no problem. I heard few people having problems with it.
Fri Jan 16 2009 9:00pm |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
The procedure for clearing the DPF is in the manual.....if you drive fast enough most of the time, then it stays clean. |
Fri Jan 16 2009 9:31pm |
What experience are you talking about? Care to tell us what your problems are? Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Fri Jan 16 2009 10:31pm |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
Hmmm, interesting...
Fri Jan 16 2009 10:59pm |
this was in my gallery all this while...
Fri Jan 16 2009 11:18pm |
Bobby, I know what a DPF does and how it functions...
Fri Jan 16 2009 11:33pm |
I now have 8500 Km on the TDV8, never had the DPF full message yet. I do quite often a bit of highway, lets say couple of times a week. '08 RRS TDV8
Fri Jan 16 2009 11:41pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
At ~25,000 Km's on my 08 TDV6 and no problems with the DPF, never had a message. i hear it carrying out the burn cycle every now and again as it makes the engine sound slightly different on start up! |
Fri Jan 16 2009 11:58pm |
OK. The exhaust emissions are a complex mixture of solid and liquid components. These are going to clog up the DPF. That's why it gets full. However, the DPF is able to regenerate, meaning the obstucting particles trapped in the filter can be burnt away so that the exhaust gases can flow freely. This process is not noticeable by the driver. DPF regeneration is controlled by the temperature of the exhaust gases and the DPF. These in turn are controlled by the DPF software located in the ECM. The DPF software monitors the load status of the DPF and also other signals from different pressure/temperature sensors. When the loading reches a predetermined level, the DPF will start the regenerating process. There are two processes involved, passive and active. Long story, so we shall not go into it now. Anyway, if the above regeneration is not working in your vehicle, it could be the software problem in the ECM or any of the pressure/temperature sensors. Its Saturday morning here and I've not had my coffee yet! Please excuse! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sat Jan 17 2009 12:00am |
Bobby, not meaning to question your omniscience about all things RRS... but I would suggest it is noticable to the driver as the engine noise changes slightly whilst the burn cycle occurs.. IMO anyway! |
Sat Jan 17 2009 5:53am |
well i got one of the first DPFs available by LR installed (after car purchase) and they have been all faulty now i am waiting since a year to get a new one installed - but still LR Germany says: not yet available due to technical probs.....
Sat Jan 17 2009 7:49am |
Bobby, how was the coffee?
Sat Jan 17 2009 7:56am |
Korenai Member Since: 05 Oct 2008 Location: Lugano Posts: 244 |
30.000 kms on the clock and no problems... Maybe the 2-stroke oil mixed with diesel helps? |
Sat Jan 17 2009 10:33am |
