![]() | Home > Maintenance & Modifications > Added Vibrations from larger wheels |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 ![]() ![]() ![]() |
Wheel balance?? RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
no its not that, it happens with ever vehicle. LR advises not to fit 20" wheels to TD6 models due to this.... L319 D4 HSE
I also had vibrations in steering wheel on 20"... then I did wheel position, wheel balance and everything OK.
bananaman Member Since: 22 Jan 2009 Location: uk Posts: 7 ![]() |
the vibration is due to your vehicle fitted with a 'non-damped' steering rack. the only way to stop it would be to replace your steering rack with a 'damped' version. not cheap!! |
RR, this has been a well known problem for L322 since launch and was one of the reasons LR said that anybody running bigger than factory issue wheel/tire combos would immediately invalidate their warranty. The explanation I was given by a dealer was that with bigger wheels invariably people fit much lower profile tyres which have less
jmm Member Since: 06 Sep 2008 Location: St Paul de Vence/ Praesto (DK) Posts: 171 ![]() ![]() ![]() |
Well, I'm now using 19' wheels fitted with winter tyres and I confirm that my ride is noticeably smoother and that I feel less vibration both idling and at speed than my drive with the standard 20' with summer tyres. |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I have wheel vibrations at 100kmh and have just had to have a new steering rack fitted. Better but not right and in a couple of weeks I am having a new rear diff.......courtesy of LR.....all on a 9 month old 10,000 highway klm car....
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 ![]() ![]() ![]() |
I have 22's on mine and have not experienced the same vibrations as you report. Perhaps a bit more of a choppy ride on uneven roads, but that's it. Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
RRUK's is a FFRR not an RRS |
