Home > Maintenance & Modifications > Added Vibrations from larger wheels
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I read that this would be an issue of I increased the wheel size on my car.
I only went from 18" to 19" but have noticed that when idling at traffic lights and in Drive, there is increased vibration directly to the steering wheel. If you knock it into Neutral, it goes away.
Can someone explain why this happens? I just can't figure out a reason.... Idea L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #191313 Wed Oct 08 2008 2:49pm
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
Wheel balance?? RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191320 Wed Oct 08 2008 3:03pm
RRUK
no its not that, it happens with ever vehicle. LR advises not to fit 20" wheels to TD6 models due to this.... L319 D4 HSE
1982 Series 3 SWB
Post #191322 Wed Oct 08 2008 3:05pm
dadanek
I also had vibrations in steering wheel on 20"... then I did wheel position, wheel balance and everything OK.
Check the wheel position, its also important. RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191329 Wed Oct 08 2008 3:13pm
bananaman
the vibration is due to your vehicle fitted with a 'non-damped' steering rack. the only way to stop it would be to replace your steering rack with a 'damped' version. not cheap!!
Post #207716 Fri Jan 23 2009 12:11am
Tim in Scotland
RR, this has been a well known problem for L322 since launch and was one of the reasons LR said that anybody running bigger than factory issue wheel/tire combos would immediately invalidate their warranty. The explanation I was given by a dealer was that with bigger wheels invariably people fit much lower profile tyres which have less
ability to absorb the engine vibes in drive, the taller rubber offering more resistance to the vibes having stiffer sidewalls. At one time this was also linked to the exploding front diffs that the 4.4V8s suffered from but was later discounted as the cause. It's like the knock in RRS's DR systems - a characteristic! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #207791 Fri Jan 23 2009 9:22am
jmm
France 2008 Range Rover Sport TDV6 HSE Tonga Green
Well, I'm now using 19' wheels fitted with winter tyres and I confirm that my ride is noticeably smoother and that I feel less vibration both idling and at speed than my drive with the standard 20' with summer tyres.
Post #207806 Fri Jan 23 2009 10:27am
BKHK
I have wheel vibrations at 100kmh and have just had to have a new steering rack fitted. Better but not right and in a couple of weeks I am having a new rear diff.......courtesy of LR.....all on a 9 month old 10,000 highway klm car....
I daren't fit any different wheels, it could cost me a fortune of it wasn't covered under warranty. Big Cry Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #207846 Fri Jan 23 2009 11:48am
gazza500
Jersey 2008 Range Rover Sport TDV6 HSE Chawton White
I have 22's on mine and have not experienced the same vibrations as you report. Perhaps a bit more of a choppy ride on uneven roads, but that's it. Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Privacy Glass, 22 inch, Hawke Alloy Wheels, Brembo Front Brakes, Premium ICE Pack, Clear repeaters, Chrome Driving Light Surrounds, Tasmods, Chrome handles, HST Grille, Chrome Side Vents, JE ECU Upgrade
Post #207853 Fri Jan 23 2009 12:07pm
RRUK's is a FFRR not an RRS Very Happy
Post #207854 Fri Jan 23 2009 12:14pm
