Home > General > Embarrased to ask this question ......... but
MX
United Kingdom 2008 Range Rover Sport TDV6 SE Java Black
I noticed last night that when I drove into my street, a light seemed to flash on the side I was indicating. Only happened once then stopped. Obviously intrigued at this I did the same again when sat on the drive and hey presto - I have an orange and a White light that flashes! I had a look at the headlight unit and there is a halogen bulb sitting there that seems to be the culprit.
When I look in the manual I see AFS and cornering lamps mentioned. Are these one and the same thing? How do I see the advantage of the cornering lamp if it only flashes for a second when the indicator is flashing?
OK.....I expect a series of replies stating something blindingly obvious that I have clearly missed in the manual Embarassed
Thanks all RRS TDV6 SE Java Black +towpack +tintent +Permagrin
What a difference between this and my old Disco3
Formerly mxgeldar7
Post #162063 Fri Mar 28 2008 11:20am
Rupert
Ireland
The cornering lamp should stay on, until the indicator is cancelled.
So if the cornering lamp flashed on once & then went out there might be a loose connection, or the bulb isn’t in it’s holder correctly.
Have you checked out the other side, to see what that is doing ??
Post #162065 Fri Mar 28 2008 11:25am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
The cornering lamps only work whilst indicating and travelling below 22mph. They are designed to light up the apex of the corner you are turning into.
They should stay on until you cancel the indicator.
Did you say that the light was flashing with the indicator? If so this is wrong, it should be a constant light. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #162066 Fri Mar 28 2008 11:28am
MX
thanks - both behave the same, only flash once. Is it dependent on wheel orientation as well, or just the indicator? RRS TDV6 SE Java Black +towpack +tintent +Permagrin
Formerly mxgeldar7
Post #162067 Fri Mar 28 2008 11:29am
Rupert
Ireland
No, wheel orientation has no bearing on it, just indicator & road speed.
Post #162068 Fri Mar 28 2008 11:30am
If both behave the same maybe a fault in the control module somewhere (presuming there's a central lighting module).
Post #162084 Fri Mar 28 2008 12:44pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
If you have the Adaptive lights and you are turning, the corner lights will come on without the indicator being on Sons of dogs come hither and get flesh
Clan Cameron
Post #162094 Fri Mar 28 2008 1:12pm
Tim in Scotland
I can confirm Alicatt's post Thumbs Up 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #162112 Fri Mar 28 2008 1:59pm
monkey9952
True , i have adaptive no indicator needed for them to come on
Post #162113 Fri Mar 28 2008 1:59pm
So what about the flashing - does that not still indicate abnormal behaviour? Confused
Post #162128 Fri Mar 28 2008 2:17pm
monkey9952
I'd say trip to stealer , mine dont flash Exclamation
Post #162131 Fri Mar 28 2008 2:22pm
Bobby
Flashing is a crime over here! Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #162280 Fri Mar 28 2008 9:50pm
And over here well it is when VA dose it RRS TDV6 Gone but still around
Post #162290 Fri Mar 28 2008 10:29pm
Bobby
Rolling with laughter Rolling with laughter Rolling with laughter Malaysia Boleh!
Post #162296 Fri Mar 28 2008 11:01pm
aaron14051989
United Kingdom 2008 Range Rover Sport Supercharged HST Izmir Blue
YER ITS ABNORMAL NEVER HEARD OF IT BEFORE IT SHOULD BE A SOLID LIGHT WHEN EITHER THE INDICATOR IS APPLIED OR UR TURNING. DOES THE ACTUAL INDICATOR FLASH IN THE HEADLIGHT CLUSTER.
Post #162297 Fri Mar 28 2008 11:04pm
