Home > Technical > How to change front diff breather valve/filter/vent
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
One of the causes of front diff failure has been the breather hose filter clogging up and not allowing the pressure within the diff to escape. This in turn causes a build up of pressure and forces oil out of the seals. This does not affect rear diff or the transmission breather hoses.
Land Rover have released an updated part, however they have not made it standard procedure to swap out. Everyone should change this part if they do not have the new style vent.
Parts:
Breather vent/valve/filter - LR019450
Tools:
Cable cutters
TSB guide: http://www.disco3.co.uk/gallery/albums/use...b00245.pdf
More details on installing the filter/data sheet: http://www.disco3.co.uk/gallery/thumbnails.php?album=23952
Time: approx 10 minutes
Step 1:
Locate the breather hose. The original one is thin and faces straight up.
Step 2:
The TSB advises to cut the pipe diagonally, 20mm from the top of the filter. The pipe is not easy to cut so I used cable cutters. The angle needs to face the rear of the vehicle like this (front |\ rear)
Step 3:
Hold the breather pipe and push the new filter down as far as it will go, ensuring it faces the REAR of the vehicle
Job Done!
Old and new:
Old filter dissected - melted foam as expected
 Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #377031 Fri Mar 15 2013 2:36pm
Paddi
Thumbs Up Another great 'how to' well done. LR Dealer did the filter change on my car but the diff had already failed! 2008 MY Java Black TDV8 HSE
Post #377045 Fri Mar 15 2013 3:52pm
Do we know where the transmission and rear diff breather vents are located? Do these also fail in the way that the front diff breather does? 2012 SDV6 - it's missing a couple of cylinders
Post #377318 Mon Mar 18 2013 12:59pm
kav1187
Thanks Paddi Thumbs Up
RRSTDV8 - Not sure on the locations of the other two, however this appears to only be a problem with the front diff vent as the foam inside melts from the heat of the engine. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #377322 Mon Mar 18 2013 1:33pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Thanks for the info, just found this link which gives more detail http://www.disco3.co.uk/gallery/thumbnails.php?album=23952 Thumbs Up
Post #377325 Mon Mar 18 2013 1:52pm
Disco_Mikey
Gearbox and transfer box breathers run along the top of the gearbox, and exit around the vacuum pump area.
The rear diff breather travels up with the fuel filler pipes behind the wheelarch liner.
None of these have any valves or filters on them Thumbs Up
Post #377326 Mon Mar 18 2013 1:56pm
kav1187
Thanks for the input guys - guide has been updated accordingly Smile Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #377328 Mon Mar 18 2013 2:16pm
Thanks for the info. Thumbs Up
Just need to find the vacuum pump now... Rolling with laughter
Oh, and I've ordered a breather valve for the front diff. May as well fit it - might help to delay front diff seals failing... 2012 SDV6 - it's missing a couple of cylinders
Post #377363 Mon Mar 18 2013 5:18pm
Replaced the breather valve today. The pipe on mine appears to be a little shorter than yours so my new valve is just touching the adjacent pipes. Not ideal but, as the original valve was U/S it can't be any worse than it was. Hopefully all will be well. 2012 SDV6 - it's missing a couple of cylinders
Post #378519 Tue Mar 26 2013 11:36pm
1JBS
Did mine, a little bit fiddly but got there in the end...many thanks for the heads up Thumbs Up
Post #378689 Wed Mar 27 2013 11:51am
Paul Holywood
Very well explained notes taken, thanks Wink
Post #406824 Fri Dec 20 2013 5:51pm
Peanut
Did mine today and also changed the front diff oil. Grateful thanks for the write up! I did a few miles then snipped off the old breather - immediate puff as pressure released - proving it was duff. I spotted the problem a few months earlier as when changing the engine oil I noticed one half shaft seal was slightly leaking. Would not have seen this without taking the lower main cover off.
Again following instructions on the site I found the filler hole and undid it and then drained the oil out.
The magnetic drain plug had done it's job and there were a few filing there! But the main reason for writing this is that the oil that came out was like creamy drinking chocolate! I suspect this may be the first change at 106K miles.
Incidentally I had no problem using the normal contaier and squirting in 600ml.
If that is the case I think I had better change the rear diff oil as well!
Post #415309 Mon Feb 24 2014 3:50pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
thanks for great info,replaced my breather and diff oil today,old breather was Censored and diff oil was like mud,rear ones next Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #415805 Thu Feb 27 2014 5:40pm
