![]() | Home > Technical > Dab Gremlin? |
RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 67 ![]() ![]() ![]() |
Hello,
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Spent the last couple of hrs reading up on this on various forums as my 2010 also has pants DAB.
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 246 ![]() ![]() ![]() |
That sounds great if it works let us know asap, Mine is working however, When i selct dab it wont turn on until i press off dial then turn it back on and dab will select but i then have to turn the volume dial one turn left or right and it works fine, So theres a quick work around but im thinking it might be a fault with the unit, I bought it off ebay from a salvage place so i doubt they test them. I can return it but only have a week left to return which i will if the dab+ module works. If you can let us know the part number. Cheers
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5061 ![]() ![]() ![]() |
L/R used to do a kit to upgrade from DAB to DAB2, not sure if still available, but had the usual L/R overpriced tag of £500.00+ |
Ouch, Think i will stick with this buggy one for now, unless i can get the dab+ from a salvage yard and its a straight swap over. |
The stupid thing is from L/R just the receiver on it's own, is nearly twice the price of the upgrade kit with wiring and receiver.
DAB+ module arrived today, but too blummin cold to go rooting around in the boot and working with wiring. I also need to make an adapter cable as the connections on old DAB and new DAB+ are different.
I'd be interested to see how this goes to be honest.
I’ll share everything once I know it works. Away this weekend, but hopefully will get some time on Sunday weather permitting. |
Update and success !
Thats brilliant Jonny So i need the dab+ module and that adapter for £30 and its plug and play all working dab+? I have just ordered the module of ebay got one for £76 with ebay coupon, Just need the plug now, That second link you posted doesnt work mate? |
When you say dismantle part of the loom, can you confirm what needs to be done?
Apols - try this link https://www.ebay.co.uk/itm/135528730041
That link works perfect, Im happy cutting the old plug off and then its just crimp the new one on and plug and play, Easy upgrade and all for £86 i think this is an upgrade well worth doing, Virgin chilled on dab+ buzzing 😃 Thanks Jonny for the info. |
