Home > Technical > Dab Gremlin?
Page 2 of 4 <1234>
JonnyCJ
Welcome - let us know how you get on !
Post #646632 Sat Feb 01 2025 4:45pm
JonnyCJ
Dean - sorry, missed your PM from earlier in the week. Can’t seem to open it for some reason but PM sent back.
Jonny
Post #646635 Sat Feb 01 2025 6:14pm
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Jonny,
Sent you a PM ref contacting you for advice.
Check your PM’s, see if it’s come through.
Dean
Post #646636 Sat Feb 01 2025 7:11pm
JonnyCJ
Hi Dean PM says the same as your post on this thread.
Jonny
Post #646637 Sat Feb 01 2025 7:14pm
RallyeSport
I’m in the process of buying the said DAB+ module, would you mind talking me through a couple of questions I have. Would you be willing for me to contact you for a quick chat, if so pm me your details, not sure why my PM can’t be read?
Post #646638 Sat Feb 01 2025 7:19pm
Jabba
Sorry, silly question, do you need to change the antenna after changing to the DAB+ module.
I've just fitted a DAB+ module but waiting on the connector.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #646686 Tue Feb 04 2025 1:13pm
JonnyCJ
I used the existing antenna
Post #646687 Tue Feb 04 2025 1:49pm
Jabba
That's great, thanks Jonny
Post #646688 Tue Feb 04 2025 1:55pm
JonnyCJ
Only one minor glitch I’ve noticed is that when switching from normal radio to DAB, which I don’t do very often, the DAB doesn’t come straight on. You need to press the DAB button then switch the radio off and on again. DAB is then automatically selected.
4 or 5 days in and virtually no drop outs, instant reception, lots more channels and great sound quality.
Really pleased with the mod.
The minor glitch can probably be tweaked out using GAPIID and is understandable given I’m using a newer module in an older car and possibly from a different make. Col or Andy K - any thoughts ?
Post #646720 Thu Feb 06 2025 7:07am
Jabba
Thanks for the update Jonny.
Unfortunately I'm still waiting for the connector to be delivered. Evri emailed me this morning saying it's in there depot but will be delayed, typical !
Many thanks
Post #646721 Thu Feb 06 2025 7:19am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Im Same Jabba, Should have been delivered yesterday but Evri driver failed to deliver it.
Post #646722 Thu Feb 06 2025 8:05am
JonnyCJ
What DAB module did you get originally Jase ? Reading back on the thread it seems that your original issue is what I have. I think it’s just a config file or something and not an issue for me, as it takes 2 seconds to turn the audio off and on again.
I’d much rather have that than no DAB at all.
If your original replacement module is old school DAB, it sounds like the head units get a bit muddled whenever the module is switched out.
I wonder if this is the same with other modules on the car such as seats etc.
Post #646724 Thu Feb 06 2025 12:01pm
jases4x4
Yes it seems that could be case, My original just stopped working so i replaced it with another dab unit old style which has the gremlins, Have to turn dial on and off after i select dab or it worked select it, Then its selected you have to adjust volume for sound to work, So i could manage that but might aswell upgrade to dab+ and hopefully it all works which i will report back once this connecter turns up today. I think a hard reset negative to positive on battery connections might work for the gremlin if its all confused, Another thing is dab stays on when engine is off and turned off until you lock car so a few things going off.
Post #646727 Thu Feb 06 2025 1:44pm
JonnyCJ
My replacement is DAB+ and I have exactly the same as you, so it seems that the quirk applies to any DAB module that gets changed over, irrespective of whether it’s DAB or DAB+.
I’m sure one of the wise old elves will be along shortly.
Post #646728 Thu Feb 06 2025 1:55pm
jases4x4
Right, So your dab+ upgrade is not operating correctly? Have you tried a hard reset of the power, terminals off battery and bridge together which drains all power out of ecu’s etc ? Thats what i will do if my new dab+ is the same.
Post #646731 Thu Feb 06 2025 2:39pm
Page 2 of 4 <1234>
