Home > Technical > Dab Gremlin? |
RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 37 |
Hello,
Mon Jan 20 2025 8:12pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 402 |
Spent the last couple of hrs reading up on this on various forums as my 2010 also has pants DAB.
Mon Jan 20 2025 9:46pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 228 |
That sounds great if it works let us know asap, Mine is working however, When i selct dab it wont turn on until i press off dial then turn it back on and dab will select but i then have to turn the volume dial one turn left or right and it works fine, So theres a quick work around but im thinking it might be a fault with the unit, I bought it off ebay from a salvage place so i doubt they test them. I can return it but only have a week left to return which i will if the dab+ module works. If you can let us know the part number. Cheers
Mon Jan 20 2025 10:03pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5018 |
L/R used to do a kit to upgrade from DAB to DAB2, not sure if still available, but had the usual L/R overpriced tag of £500.00+
Mon Jan 20 2025 11:06pm |
Ouch, Think i will stick with this buggy one for now, unless i can get the dab+ from a salvage yard and its a straight swap over. |
Mon Jan 20 2025 11:33pm |
The stupid thing is from L/R just the receiver on it's own, is nearly twice the price of the upgrade kit with wiring and receiver.
Tue Jan 21 2025 3:43am |
