Home > Maintenance & Modifications > Apple Carplay installation into 2013 L320 SDV6 HSE
Page 1 of 3 123>
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Hello all
I have purchased an Apple CarPlay module, which has now arrived. I thought I would post up my installation step by step, blow by blow. both positives and negatives.
I will post progress with full photos, so hopefully this may help other if they choose this route.
Lets start with the product purchased.
CARABC Wireless Carplay Android Auto
https://www.aliexpress.com/item/1005004770...1802R6GN3U
This was ordered on the 31st December and delivered on 7th January. not too bad a lead time.
what arrived and what's in the box
Install will commence at the weekend
until then....
CJS
Post #646141 Tue Jan 07 2025 9:38pm
subbed --
Post #646149 Wed Jan 08 2025 7:13am
Golan
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Cool I hope it goes well for you.
I found the YouTube tutorial extremely helpful and one of those plastic trim removing tools would be useful (or an old kitchen spatula would do it) Wink
Post #646169 Wed Jan 08 2025 8:25pm
Cpt Jack Sparrow
I can confirm the installation is complete and took less than an hour including a cuppa.
I do have one issue to resolve and that is sound, more details to follow.
Full write up being put together for this thread, happy modding
CJS
Post #646215 Fri Jan 10 2025 8:54pm
Cpt Jack Sparrow
So here we go.
1) The patient
The section with the clock and ignition button is held on with clips and no screws, so it 'simply" pulls off.
in reality you need to open the top glove box and use a trim tool to leaver it off an one end them work your way along.
When you have it clear unplug the ignition, clock and mode selection looms. Remove the panelled store safely
Post #646217 Fri Jan 10 2025 9:51pm
Cpt Jack Sparrow
Now time for Torx 20 screw removal. Initially there are 6
the 4 on the Vents will then allow you to just lift out the Vents out and store safely. Once the vents are out, this will reveal 2 either side of the screen at the top. once these are taken out the screen will lift out.
remove by manoeuvring from the bottom first, might need a bit of a wiggle but its pretty simple once you try.
Then unplug all of the wires on the back and store the screen.
You now have a huge space staring at you
No need to label each plug as they are colour coded and only fit in one place.
Next is what I found to be one of the hardest parts, unplugging the main large loom from the back of the CD head unit.
Post #646218 Fri Jan 10 2025 10:08pm
Cpt Jack Sparrow
Now is time to start installation of the kit.
Main loom first, I went for the largest plug back into the CD/Head unit, again a faff to get it in, the right angle and getting fingers in was challenging to say the least, Then click it was in. Very Happy
the original loom then goes into the female plug on the new loom.
I decided it was now a good time to mock the whole set up together and test. to do this I removed the start button from its panel and plugged it onto its looms.
its pretty self explanatory what goes where, the one that throws you is the original Blue square video plug is now redundant and not used. a new one runs from the screen to the new control module in the kit.
once all was put together I pressed the start button to the accessory position.
and there it was...Alive... BUT off set to the left on the screen.
A quick check of the instuctions lead me to switch jumper 5 to on.
Post #646219 Fri Jan 10 2025 10:30pm
Cpt Jack Sparrow
Time to put it all back together.
up under the dash pad behind the screen is the perfect slot to put the module. so in it went. a tidy up of the wires and routing the USB cable into the top glove box.
then in with the screen top in first and then the bottom.
Oh and how did the jumper switch work?
Then the vents and finally connect the clock start button and nav controls and finally freed the whole panel back into place.
Post #646220 Fri Jan 10 2025 10:42pm
Cpt Jack Sparrow
All so smooth and simple to do, and happy with the install...
HOWEVER
Currently I have no sound from Apple CarPlay coming through my speakers, Checked and doubled check all connections and nothing wrong.
phone is disconnected and forgotten by the Cars internal system.
I have contacted the supplier for help.
Update to follow Thumbs Up
Post #646221 Fri Jan 10 2025 10:50pm
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
My Carplay is an entirely different unit but to get sound from the system I had to insert a dummy plug into the Aux port and then select Aux from the Audio menu.
Not sure if you can do that with yours though. Can you still get the original settings menus, 4WD info on your screen?
Post #646222 Fri Jan 10 2025 11:39pm
Cpt Jack Sparrow
Yes, all the original screen controls are there except NAV,
Instructions to say to have the system set to AUX but still no Joy
What does the dummy plug look like other do?
CJS
Post #646223 Fri Jan 10 2025 11:41pm
AndyCHO
It is basically an earphone plug with the wires connected together as far as I can tell.
The same thing also needs to be done with the "Tesla" style additions for Carplay.
If you have an old headphone jack just cut the wires and join them to see if it works.
Good luck, looks to be a nice system. Mine was much more complicated to do.
Post #646224 Fri Jan 10 2025 11:46pm
It may be different but on the idcore if I remember right you had to plug a lead from the unit into a 3.5mm jack plug to get sound through the speakers via Aux, initially I used the jack plug under the flap in the rear before I wired it in to the harness.
Post #646225 Fri Jan 10 2025 11:50pm
Cpt Jack Sparrow
Thanks for the explanation
sounds like i'll have a go. Thumbs Up
Post #646226 Fri Jan 10 2025 11:52pm
Cpt Jack Sparrow
Thanks Col
I do believe its some I have or haven't done as @Golan has installed the same system with out this issue.
CJS Thumbs Up
Post #646227 Fri Jan 10 2025 11:55pm
Page 1 of 3 123>
