![]() | Home > Maintenance & Modifications > Apple Carplay installation into 2013 L320 SDV6 HSE |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 168 ![]() ![]() ![]() |
Hello all
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1195 ![]() ![]() ![]() |
subbed --
I can confirm the installation is complete and took less than an hour including a cuppa.
So here we go.
Now time for Torx 20 screw removal. Initially there are 6
Now is time to start installation of the kit.
Time to put it all back together.
All so smooth and simple to do, and happy with the install...
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
My Carplay is an entirely different unit but to get sound from the system I had to insert a dummy plug into the Aux port and then select Aux from the Audio menu.
Yes, all the original screen controls are there except NAV,
It is basically an earphone plug with the wires connected together as far as I can tell.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
It may be different but on the idcore if I remember right you had to plug a lead from the unit into a 3.5mm jack plug to get sound through the speakers via Aux, initially I used the jack plug under the flap in the rear before I wired it in to the harness.
Thanks for the explanation
Thanks Col
