Home > Maintenance & Modifications > Apple Carplay installation into 2013 L320 SDV6 HSE |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 154 |
Hello all
Tue Jan 07 2025 8:38pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1173 |
subbed --
Wed Jan 08 2025 6:13am |
I can confirm the installation is complete and took less than an hour including a cuppa.
Fri Jan 10 2025 7:54pm |
So here we go.
Fri Jan 10 2025 8:51pm |
Now time for Torx 20 screw removal. Initially there are 6
Fri Jan 10 2025 9:08pm |
Now is time to start installation of the kit.
Fri Jan 10 2025 9:30pm |
Time to put it all back together.
Fri Jan 10 2025 9:42pm |
All so smooth and simple to do, and happy with the install...
Fri Jan 10 2025 9:50pm |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 122 |
My Carplay is an entirely different unit but to get sound from the system I had to insert a dummy plug into the Aux port and then select Aux from the Audio menu.
Fri Jan 10 2025 10:39pm |
Yes, all the original screen controls are there except NAV,
Fri Jan 10 2025 10:41pm |
It is basically an earphone plug with the wires connected together as far as I can tell.
Fri Jan 10 2025 10:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5004 |
It may be different but on the idcore if I remember right you had to plug a lead from the unit into a 3.5mm jack plug to get sound through the speakers via Aux, initially I used the jack plug under the flap in the rear before I wired it in to the harness.
Fri Jan 10 2025 10:50pm |
Thanks for the explanation
Fri Jan 10 2025 10:52pm |
Thanks Col
Fri Jan 10 2025 10:55pm |
