Home > Maintenance & Modifications > What a total
Page 2 of 4 <1234>
JonnyCJ
Where exactly are you in Scotland ? Must be someone who knows someone.
Post #645932 Fri Dec 27 2024 5:28pm
Axl
2010 Range Rover Sport TDV8 HSE Adriatic Blue
Glasgow I've got the number of someone in Ayrshire so will ask.
Post #645933 Fri Dec 27 2024 6:39pm
JonnyCJ
What about RR Glasgow ? Just googled them Indy and Rangey specialists, so know their onions and you’re not paying dealer prices.
Post #645934 Fri Dec 27 2024 7:14pm
Axl
Thanks I've not heard of them but will ask on Monday.
Post #645942 Fri Dec 27 2024 9:55pm
Disco_Mikey
RAC wouldn't do something like that roadside. They'd only recover you to a garage or home, but I do like your thinking Laughing
3.6 is probably one of the worst alternators JLR decided upon, but still easier than an L322 SDV8 Whistle
Post #645943 Fri Dec 27 2024 10:54pm
Axl
I know they (AA in my case) won't fit it at the roadside but they'll book it in for a mech to come out and do it and wondered if they did it.
Yes it's a proper pita of job, I know what do but can't get to the stuff I need to get to to get it on.
Post #645944 Fri Dec 27 2024 11:10pm
gogsy1956
Certainly easier to get it out than put it back in,, trying to put the bottom bolts in last is next to impossible,, I resorted to putting the two bottom bolts in place on the alternator then put the alternator back in place,,,, and don't let the bolts slip out in the process. Hang it off the top bolt then a short 13mm half a turn at a time to do the bottom ones. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #645952 Sat Dec 28 2024 7:24pm
Axl
I can't get even get the bloody thing out never mind the new one in!
Post #645953 Sat Dec 28 2024 7:29pm
gogsy1956
It is a bit a tight fit,, you need to rotate it and it will come out beside the ACE pipes 2010 RRS, TDV8
22" overfinch
Post #645955 Sat Dec 28 2024 9:40pm
d-9
It’s a pita. Mine caught fire and I was thinking about doing it in the hotel car park. Called my mechanic and he told me I probably didn’t want to try that.
Off the top of my head, you need to:
- drivers wheel off, arch liner out
- boost pipes off the top
- fan shroud top section off (I modified mine so I didn’t have to drain the rad to get this off)
- fan off (be careful not to put the viscous fan spanner through the rad hose, bottom hoses are NLA. Recommend wrapping the fan spanners in duct tape to protect the hoses)
- bottom drivers side boost hose off
- pull the hard pipe to the turbo down so you can access the alternator bolts
- undo the 13mm bolts holding the alternator on.
- lift the alternator out the top.
- file a chamfer on the inner faces of the horizontal mounting bolt holes on the new alternator so it slides on easier
- drop the new alternator in the top, wrestle it onto the engine. Bolt it back up.
- etc.
Doing it again, I’d buy a 13mm 1/4” UJ socket for the two bolts that go in from the bottom, they’re a massive pita to access.
Post #645956 Sat Dec 28 2024 9:43pm
Axl
Sorry what i mean is, I can't get the bottom pipe off that's right against the 2 10mm bolts at the alt, well I can (the one that's attached to the metal pipe) i think to the turbo if not it's a coolant pipes and don't want it (coolant from another pipe) in my eyes again.
I guess if I got that or the way then I could probably start fighting getting the alternator out etc.
Post #645957 Sat Dec 28 2024 10:01pm
Axl
- etc.
Thanks for your explanation on how you did it.
I bought the proper 36mil spanner and getting the fan, shroud, pipes etc was really quite easy, watching what I was doing though working close to the rad.
As I was saying above, it's mainly (well so far) the pipe connected to the metal pipe in wary of loosening incase of a coolant pipes and get it in my eyes again (bloody stung and got a fright incase it did something to my sight).
What's NLA
Post #645958 Sat Dec 28 2024 10:07pm
Disco_Mikey
No Longer Available
Same as dipstick and tubes + gearbox pipes. Guess what mine needs Big Cry
Post #645959 Sat Dec 28 2024 11:01pm
Axl
On a 15 year old car in my case and things like you can't get, that's a bit Censored . So it needs to be evilbay or somebody breaking.
You know, the more I hear about stupid crap like like this and the reliability in general the more I don't think I'd have another.
Post #645960 Sat Dec 28 2024 11:10pm
d-9
Do you mean the metal pipe in the picture I posted above? If so that’s a turbo pipe. IIRC I had to undo a bolt or two that held the turbo pipes onto the chassis legs, but it’s been a while and I’ve tried to forget the whole experience. I definitely didn’t undo any coolant pipes when I did mine.
Recommend wearing safety glasses when you’re grotting around under an old car. If your a glasses wearer, specsavers sell prescription safety glasses.
Post #645961 Sat Dec 28 2024 11:14pm
Page 2 of 4 <1234>
