Home > General (L494) > RRS SVR 2015 heater blowing cold air |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 |
Sounds like the thermostat is not opening |
Sun Dec 01 2024 3:16pm |
Grantgronow0705 Member Since: 30 Nov 2024 Location: Bridgend Posts: 9 |
Wouldn’t the system over heat or pressurise if the thermostat is not opening? |
Sun Dec 01 2024 3:17pm |
Wouldn’t the engine over heat or the system pressurise? I have managed to get heat into the car only through the fuel fired heater but soon as the car is running it’s cold. I can drive for 1 hour and still doesn’t warm up. |
Sun Dec 01 2024 4:36pm |
Ironhorse Member Since: 21 May 2024 Location: bromsgrove Posts: 10 |
sounds like it might be the changeover valve on the FBH to me
Mon Dec 02 2024 4:32pm |
I changed the valve with the FBH water pump. That side of the heating works remotely.
Mon Dec 02 2024 6:36pm |
did you clear any fault codes after you changed it |
Mon Dec 02 2024 7:35pm |
Yes, all fault codes stored in the ecu were cleared. Fault codes attached.
Mon Dec 02 2024 7:39pm |
So this evening I have had the thermostat changed and there appears to be no change. We are absolutely left baffled.
Wed Dec 04 2024 9:06pm |
So to provide everyone with an update. I put the vehicle into a specialist called HBH in Caerphilly and they have found the fault to be the engine coolant control valve which is located back end of radiator going into the engine block.
Wed Dec 18 2024 5:37pm |
