Home > General (L494) > RRS SVR 2015 heater blowing cold air
Grantgronow0705
United Kingdom 2013 Range Rover Sport Supercharged Santorini Black
Hi, my first post on this forum.
I have a RRS SVR 2015 and having issues with the heating. The car is only blowing cold air. The vehicle doesn’t lose coolant. It doesn’t over heat even on a long drive.
I have changed the pump on the side of the fuel burner heater and the solenoid underneath and still doesn’t make a difference.
Then you feel the pipes going to the heating matrix on the bulkhead, they are both cold. The pipes coming in/out of the fuel burning heater are also cold regardless of the car has been run for an hour.
Obviously we are desperate to get the issue fixed. Can anyone advise or point us in the right direction.
Any help is appreciated.
Post #645566 Sun Dec 01 2024 1:03pm
Red Arrow
Sounds like the thermostat is not opening Thumbs Up
Post #645568 Sun Dec 01 2024 4:16pm
Grantgronow0705
Wouldn’t the system over heat or pressurise if the thermostat is not opening?
Post #645569 Sun Dec 01 2024 4:17pm
Grantgronow0705
Wouldn’t the engine over heat or the system pressurise?
I have managed to get heat into the car only through the fuel fired heater but soon as the car is running it’s cold. I can drive for 1 hour and still doesn’t warm up.
Post #645570 Sun Dec 01 2024 5:36pm
Ironhorse
sounds like it might be the changeover valve on the FBH to me
same happened on my L322
Post #645582 Mon Dec 02 2024 5:32pm
Grantgronow0705
I changed the valve with the FBH water pump. That side of the heating works remotely.
I’m going to change the thermostat tomorrow as I have noticed the coolant pipe underneath the expansion bottle with the bleed nipple is stone cold even after a long drive.
Post #645583 Mon Dec 02 2024 7:36pm
Ironhorse
did you clear any fault codes after you changed it
Post #645584 Mon Dec 02 2024 8:35pm
Grantgronow0705
Yes, all fault codes stored in the ecu were cleared. Fault codes attached.
The only code that keeps coming back is the windshield misting sensor.
Post #645585 Mon Dec 02 2024 8:39pm
Grantgronow0705
So this evening I have had the thermostat changed and there appears to be no change. We are absolutely left baffled.
We have now had the thermostat, heating solenoid and pump on the FBH changed.
When I feel the pipes going into the heater matrix, they are cold. The pipes directly under the expansion bottle are also cold. The pipe south of the thermostat is also cold even after running the car for an hour.
We are now booking into a main dealership!
Post #645622 Wed Dec 04 2024 10:06pm
Grantgronow0705
So to provide everyone with an update. I put the vehicle into a specialist called HBH in Caerphilly and they have found the fault to be the engine coolant control valve which is located back end of radiator going into the engine block.
I suspected it was this before putting into the garage but was told by others my car doesn’t have that part and it’s from 2018 onwards. Lesson learned to go with the gut instinct…….
Hopefully, the car will be back tomorrow afternoon with heating.
Post #645851 Wed Dec 18 2024 6:37pm
