Home > General (L494) > RRS SVR 2015 heater blowing cold air |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 588 |
Sounds like the thermostat is not opening |
Sun Dec 01 2024 3:16pm |
Grantgronow0705 Member Since: 30 Nov 2024 Location: Bridgend Posts: 8 |
Wouldn’t the system over heat or pressurise if the thermostat is not opening? |
Sun Dec 01 2024 3:17pm |
Wouldn’t the engine over heat or the system pressurise? I have managed to get heat into the car only through the fuel fired heater but soon as the car is running it’s cold. I can drive for 1 hour and still doesn’t warm up. |
Sun Dec 01 2024 4:36pm |
Ironhorse Member Since: 21 May 2024 Location: bromsgrove Posts: 4 |
sounds like it might be the changeover valve on the FBH to me
Mon Dec 02 2024 4:32pm |
I changed the valve with the FBH water pump. That side of the heating works remotely.
Mon Dec 02 2024 6:36pm |
did you clear any fault codes after you changed it |
Mon Dec 02 2024 7:35pm |
Yes, all fault codes stored in the ecu were cleared. Fault codes attached.
Mon Dec 02 2024 7:39pm |
So this evening I have had the thermostat changed and there appears to be no change. We are absolutely left baffled.
Wed Dec 04 2024 9:06pm |
