![]() | Home > General (L494) > RRS SVR 2015 heater blowing cold air |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 591 ![]() ![]() |
Sounds like the thermostat is not opening |
Grantgronow0705 Member Since: 30 Nov 2024 Location: Bridgend Posts: 9 ![]() ![]() ![]() |
Wouldn’t the system over heat or pressurise if the thermostat is not opening? |
Wouldn’t the engine over heat or the system pressurise? I have managed to get heat into the car only through the fuel fired heater but soon as the car is running it’s cold. I can drive for 1 hour and still doesn’t warm up. |
Ironhorse Member Since: 21 May 2024 Location: bromsgrove Posts: 16 ![]() ![]() |
sounds like it might be the changeover valve on the FBH to me
I changed the valve with the FBH water pump. That side of the heating works remotely.
did you clear any fault codes after you changed it |
Yes, all fault codes stored in the ecu were cleared. Fault codes attached.
So this evening I have had the thermostat changed and there appears to be no change. We are absolutely left baffled.
So to provide everyone with an update. I put the vehicle into a specialist called HBH in Caerphilly and they have found the fault to be the engine coolant control valve which is located back end of radiator going into the engine block.
