Home > Maintenance & Modifications > L320 2008 - A Pillar Window Mouldings
Meshan
Hi all,
I replaced my slam panel as it was no longer touching the window.
Looking at the A Pillar covers/moldings, the foam has deteriorated, so looking to refresh or replace.
Does anyone have any experience with doing this?
Can you use aftermarket or should you use OEM/EM versions?
I only ask as they are not readily available.
Maltings sell some made by Allmakes 4x4. Are these ok?
Any help very much appreciated.
Post #645388 Fri Nov 22 2024 9:48am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
I refurbished mine pretty simple job to be honest
Look here https://www.rrsport.co.uk/forum/topic59578.html
Post #645389 Fri Nov 22 2024 9:50am
Meshan
Thanks, I'll have a look.
Did you replace the foam and the foam "button" Mine has turned to mush,.
Just to add, it's the external moldings. L320 Range Rover Sport 2008
3.6 TDV8
Post #645390 Fri Nov 22 2024 10:09am
Lrstaylor
I havnt done anything to my external A pillar trims except remove and refit a couple of times with new fixings and extra water proofing
Post #645401 Fri Nov 22 2024 8:25pm
Meshan
Thank any way.
I've bought some replacements as mine let in water and whistle quite badly.
They didn't fit very well, but I've replaced the scuttle panel and everything seems to fit better. L320 Range Rover Sport 2008
3.6 TDV8
Post #645403 Fri Nov 22 2024 8:40pm
Lrstaylor
New clips every time mines getting a new screen next week iv got a bag full of new clips ready for autoglass fitter
Post #645404 Fri Nov 22 2024 10:31pm
JonnyCJ
New screen for me today - I had a stone chip right in my eyeline, which would normally have been repaired, however, as it damaged the heated screen element it was deemed irreparable, so Autoglass fitted a new screen.
They also fitted new A pillar trims and clips - which was nice.
I'll put some Aerospace 303 UV protector on them when not stops raining, which should keep them spick and span for a while.
It was this thread that actually prompted me to get my screen done, as the driver's side A pillar trim had a cracked clip locator and wasn't sitting flush, so thanks very much !
Nb - the screen was aftermarket, but fits perfectly and you wouldn't know it wasn't a JLR one. The insurance co wanted £900 excess for a JLR one.
Post #645650 Fri Dec 06 2024 4:58pm
Meshan
How much was the windscreen?
I have a chip in mine, not an MOT failure, just a pain.
2 new a pillar covers later and they fit like a glove. I think they move over time - and fade terribly. L320 Range Rover Sport 2008
3.6 TDV8
Post #645652 Fri Dec 06 2024 5:06pm
JonnyCJ
£115 excess for the screen. I think it's £25 - £60 if it's just a repair, but you don't get new A pillar trims Very Happy
Post #645653 Fri Dec 06 2024 5:10pm
Lrstaylor
Something here autoglass just fitted a new screen for me last Thursday they fitted new external A pillar trims as standard the fitter says they always break when they remove them. I had a stone chop drivers side lucky me as the passenger side heated screen was dead.
Sods law no frost since Rolling with laughter
Post #645654 Fri Dec 06 2024 7:14pm
