Home > Maintenance & Modifications > L320 2008 - A Pillar Window Mouldings
Meshan
Hi all,
I replaced my slam panel as it was no longer touching the window.
Looking at the A Pillar covers/moldings, the foam has deteriorated, so looking to refresh or replace.
Does anyone have any experience with doing this?
Can you use aftermarket or should you use OEM/EM versions?
I only ask as they are not readily available.
Maltings sell some made by Allmakes 4x4. Are these ok?
Any help very much appreciated.
Post #645388 Fri Nov 22 2024 9:48am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
I refurbished mine pretty simple job to be honest
Look here https://www.rrsport.co.uk/forum/topic59578.html
Post #645389 Fri Nov 22 2024 9:50am
Meshan
Thanks, I'll have a look.
Did you replace the foam and the foam "button" Mine has turned to mush,.
Just to add, it's the external moldings. L320 Range Rover Sport 2008
3.6 TDV8
Post #645390 Fri Nov 22 2024 10:09am
Lrstaylor
I havnt done anything to my external A pillar trims except remove and refit a couple of times with new fixings and extra water proofing
Post #645401 Fri Nov 22 2024 8:25pm
Meshan
Thank any way.
I've bought some replacements as mine let in water and whistle quite badly.
They didn't fit very well, but I've replaced the scuttle panel and everything seems to fit better. L320 Range Rover Sport 2008
3.6 TDV8
Post #645403 Fri Nov 22 2024 8:40pm
Lrstaylor
New clips every time mines getting a new screen next week iv got a bag full of new clips ready for autoglass fitter
Post #645404 Fri Nov 22 2024 10:31pm
