Home > General > Disco_Mikey
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Disco_Mikey
Hello,
I’m trying to get hold of Disco_Mikey to ask about epb module issues I have since yesterday.
I’ve read his procedure about the epb being ceased, but don’t think mine is yet, as I can’t still work the epb, but does screech a little. I’ve ordered a full overhaul rear brake kit - calipers x2, discs, pads, shoes and hardware, so going to fit all that and readjust everything and start from scratch, using the bodsy brake bible.
Was just wanting clarity on how the epb functioned and if what symptoms I have are saveable.
I tried phoning his business number but doesn’t ring out?
Can anyone help, maybe he’ll see this message or someone could give him a nudge for me.
Cheers Dean
Post #644398 Wed Sep 25 2024 9:33pm
He has a business to run.
He doesn’t have time to give advise on epb issues.
Post #644399 Wed Sep 25 2024 10:24pm
RallyeSport
Thanks to his PA, that answered that question.
Post #644403 Thu Sep 26 2024 4:31am
NoExpert
If it’s just screeching then you could probably just adjust the shoes. You definitely want to follow the instructions word for word, including adjusting the wedge and torquing it to spec. I’d discontinue using the parking brake now before it seizes, that’s a can of worms you really don’t want to open. Ask whatever questions you have. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #644405 Thu Sep 26 2024 7:54am
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
On the meantime if the brake comes on automatically when you stop the engine take the fuse out to stop it working, if it jams you will have a major job.
Post #644408 Thu Sep 26 2024 11:03am
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Ehup
I used Bodys and got advice from NoExpert Thumbs Up , just follow the instructions on set up and mine worked a treat after completing
Adjusting the little wedge on set up and torquing correctly certainly assisted me
Hope it goes well
Post #644428 Thu Sep 26 2024 6:52pm
daxmatt
Did he touch a nerve ?, guy was only asking a question.
You must be a genius
Post #644444 Fri Sep 27 2024 4:40pm
I just recall his post on his epb unjamming
Guide.
If one more person rings me up to ask about epb unjamming, I will delete it. Etc etc
Post #644445 Fri Sep 27 2024 5:13pm
RallyeSport
I followed bodsy’s guide to the letter, worked a treat.
I replaced everything on the back end - callipers, hoses, discs, pads and shoes.
The wedge, you mean loosening the small cap screw half a turn, tapping the disc with a mallet to bed in the mechanism and torquing (I tightened accordingly) afterwards?.
I removed the fuse as people had said, luckily the EPB wasn’t seized, maybe due to the fact a previous owner had replaced with a new genuine LR EPB back in 2022.
As for Mikey, yes he has a business to run, but he does promote himself as mingling with the public and doing jobs on the side, I’d hoped he might be contactable possibly.
I did speak with Ian Bodsworth, who is a really nice chap and very helpful, I can’t thank him enough!
All ok now, just got to sort the front end - I’m considering upgrading to 6 pot Brembos from a 5.0 SC, as mine is a 3.6 TDV8 2010 Autobiography and would be in keeping with the facelift look. Only place I can find is eBay at £800 for a pair as I don’t have a set to swap out, so have to lose out on b the £300 surcharge.
Cheers Dean
Post #644850 Tue Oct 22 2024 8:56pm
TTR
Rallyesport
Eh up, glad you got it sorted, yes I meant that adjustment on the cap screw. I painted mine orange so I could spot the dam thing😂
NoExpert pointed this out to me when I did mine, 8 months on no issues at all, Thumbs Up
Post #644876 Wed Oct 23 2024 7:14pm
RallyeSport
Hello,
Yes, everything ok so far, been away in the caravan since, everything normal operating temp on brakes, bedding pad in nicely.
Just need to sort the fronts with 6 pots preferably.
Dean
Post #644877 Wed Oct 23 2024 7:18pm
JonnyCJ
Re the six pot Brembos - I think it was Col who said there’s not much difference in stopping power between 4&6 pots. (Happy to stand corrected Col !).
I got a pair of 4 pot Brembos off eBay for £30 plus postage. Soda blasted for £80. Fitted new pistons and seals for around £60 and then etch primed and high build primed them for £15.
Some sanding down and got them painted and lacquered for £40.
I now have brand new looking and functioning 4 pots with stickers etc for approx £235. Whilst the 6 pots look meatier I doubt you’ll notice or appreciate any extra stopping power.
Just my 2p worth for an alternative solution.
Post #644947 Mon Oct 28 2024 9:54pm
JonnyCJ
Here’s my thread https://www.rrsport.co.uk/forum/post642314.html#642314
Post #644948 Mon Oct 28 2024 9:57pm
RallyeSport
Thank you for the reply.
I’ll take a look
Post #644949 Mon Oct 28 2024 10:38pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
If you look on LR Time he shows how to remove and repair it. Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #644951 Tue Oct 29 2024 9:16am
