Home > General > Disco_Mikey
NoExpert
I have four piston Brembos on my 2011 L320 and they’re a small improvement over stock. I’ve driven L320’s with the six piston Brembos and you notice the difference in brake fade time. You can heat up the 360mm four pistons faster than the 380mm six pistons.
From a pad change standpoint, I wouldn’t personally change to six piston calipers as every single time I’ve had to change brakes on them I’ve had to hack the pins out with various cutting tools and drill out the pins from the calipers. On four pistons the pins typically pop out pretty effortlessly. The last six piston calipers I did pads on the calipers had to be completey removed from the car in order to drill out the pins. Last four piston calipers I changed pads on it took a few taps from a hammer and punch to get the pins out. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #644956 Tue Oct 29 2024 3:42pm
JonnyCJ wrote:
Re the six pot Brembos - I think it was Col who said there’s not much difference in stopping power between 4&6 pots. (Happy to stand corrected Col !).
If I recall what I said was I have had both the TDV8 with 4 pots and the S/C with 6 pots the TDV8 for four years and S/C for over ten years and under what I would consider a normal style of driving I didn't think there was any vastly noticeable difference in braking, however if you needed to stand on them then the 6 pots were obviously better, so I think a lot would depend on your style of driving, if you do a lot of towing, live in a mountainous region etc. or feel the need for the big caliper look and drive it like you stole it which is the only way to drive a S/C sometimes, then maybe yes, all a personal choice I guess.
I have replaced the brake pads several times on the S/C, primarily to find a pad to get rid of the annoying squeal some of the earlier S/C's suffered from, and have had no problems removing the pins, however saying that they do not use salt on the roads here in winter which is probably a major factor, aluminium calipers and steel pins are never a good combination either, so I do smear a little ceramic brake grease on the pins when fitting them.
Post #644963 Tue Oct 29 2024 8:38pm
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Thanks for your replies.
I would like to fit 6 pots, as I feel it will be in keeping with the 2010 facelifted look.
The only problem is that to buy a reconditioned set of 6 pots from eBay, their priced at £500 for the pair and because I'm not swapping like for like (mine is 2 pot calipers TDV8), they'll also want a further £300 for not exchanging.
I know Maltings 4x4 sell Eurospare red 6 pots for £306 a side, which isn't too bad, but I know their not Brembo.
There seems to be only one company on eBay that sells reconditioned calipers, the same place I bought my refurbished rear calipers from, they do a good job of painting them and come with new fittings etc, so I assume the refurbished Brembo's would be the same quality, but with a hefty price tag of £800 for the pair, noone else sells them on ebay though, which is a shame so as to compare price.
I know I'll need the 380mm discs and pads and replace the dust sheilds which are easily interchangeable.
Anyone know where I could buy a pair of refurbished calipers cheaper than £800 and are ready to fit as they've been refurbished.
Cheers in advance
Dean
Post #644981 Wed Oct 30 2024 6:15pm
