Home > General > More electrical wiring woes on my 4.2 Supercharged |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 341 |
The A pillar exterior trim is a common water ingress failure point the clips have a seal which let's go |
Mon Feb 26 2024 7:07pm |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 |
Thanks
Mon Feb 26 2024 7:27pm |
Buy your self a whole new bunch of clips off the bay your gonna need them at somewhere point plus silicon them as well just to be sure.
Mon Feb 26 2024 7:31pm |
Cheers …
Mon Feb 26 2024 7:35pm |
Have a look here it's D3 but the sport has the sames issues
Mon Feb 26 2024 7:47pm |
Another known issue
Mon Feb 26 2024 7:49pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
There’s a connector behind the trim by throttle pedal.
Mon Feb 26 2024 9:08pm |
Thanks for all the pointers….
Tue Feb 27 2024 4:57am |
Had half an hour free this morning so whipped out the drivers seat and the sill trim cover to expose the drivers side loom.
Tue Feb 27 2024 10:57am |
Found the problem, corroded connector in the lower A pillar drivers side, looks like a couple of pins have broken off as well.
Tue Feb 27 2024 2:29pm |
Quite a mess that connector |
Tue Feb 27 2024 2:42pm |
Yep…mounted vertically so the water getting in just ran down the wiring and sat in the connector.
Tue Feb 27 2024 2:52pm |
Cut that connector out completly and solder all the wires together bit of heat shrink job done for good |
Tue Feb 27 2024 6:17pm |
Re spliced the wiring connector and I am back in business with a working multi play DVD and the sat nav drive.
Sat Mar 02 2024 10:35am |
