![]() | Home > General > More electrical wiring woes on my 4.2 Supercharged |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
The A pillar exterior trim is a common water ingress failure point the clips have a seal which let's go |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 ![]() ![]() ![]() |
Thanks
Buy your self a whole new bunch of clips off the bay your gonna need them at somewhere point plus silicon them as well just to be sure.
Cheers …
Have a look here it's D3 but the sport has the sames issues
Another known issue
There’s a connector behind the trim by throttle pedal.
Thanks for all the pointers….
Had half an hour free this morning so whipped out the drivers seat and the sill trim cover to expose the drivers side loom.
Found the problem, corroded connector in the lower A pillar drivers side, looks like a couple of pins have broken off as well.
Quite a mess that connector |
Yep…mounted vertically so the water getting in just ran down the wiring and sat in the connector.
Cut that connector out completly and solder all the wires together bit of heat shrink job done for good |
Re spliced the wiring connector and I am back in business with a working multi play DVD and the sat nav drive.
