![]() | Home > Technical > 2010 RRS gearbox replacement |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
the gearbox will work, however....you have to swap over the mechatronics control, or programe a new one. |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
I’d be curious if you could put a 6HP28 from a 3.0 TDV6 or 5.0SC in it. They are stronger gearboxes. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Yanee6804 Member Since: 12 Apr 2021 Location: Essex Posts: 20 ![]() ![]() ![]() |
This detais confused me |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
I think the TDV8 used an already stronger gearbox - the same as the 4.2S/C with an additional pinion gear and clutch plates to handle the extra grunt. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
[img]
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
If the gearbox is from a similar engined car, and of the same year, it will work without any programming.
Thank you Dave B |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Extract from a 2010/2011 workshop manual, assuming the manual is accurate of course, a earlier version does also mention same version box in the 4.2 S/C. ![]() Cheers Col |
It’s the same with the 3.0TDV6/5.0SC 6HP28 trans, they’ve been upgraded in the same way, but you get the better 6HP28 that resolved a lot of the 6HP26 problems and has a higher nominal torque value. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
