Home > Technical > 2010 RRS gearbox replacement
Yanee6804
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Fuji White
I have a 2010 3.6 TDV8 with AH42-7000DD code gearbox My question is can I replace any other gearbox from TDV8 or need the same code
Post #638625 Mon Jan 08 2024 3:06pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
the gearbox will work, however....you have to swap over the mechatronics control, or programe a new one.
Post #638866 Tue Jan 16 2024 12:17pm
NoExpert
I’d be curious if you could put a 6HP28 from a 3.0 TDV6 or 5.0SC in it. They are stronger gearboxes. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #638867 Tue Jan 16 2024 12:47pm
Yanee6804
This detais confused me
Post #638868 Tue Jan 16 2024 1:25pm
I think the TDV8 used an already stronger gearbox - the same as the 4.2S/C with an additional pinion gear and clutch plates to handle the extra grunt. 2012 SDV6 - it's missing a couple of cylinders
Post #638870 Tue Jan 16 2024 2:27pm
Yanee6804
[img]
[/img]
Post #638871 Tue Jan 16 2024 3:02pm
Dave B
If the gearbox is from a similar engined car, and of the same year, it will work without any programming.
I changed just the megatronic unit (which is the only bit that programming affects) in a SDV6 Disco 4, to that from a SDV6 Range Rover Sport, both 2011, and without programming it worked without issues.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #638876 Tue Jan 16 2024 5:42pm
Yanee6804
Thank you Dave B
Post #638877 Tue Jan 16 2024 6:38pm
RRSTDV8 wrote:
[quote=
Extract from a 2010/2011 workshop manual, assuming the manual is accurate of course, a earlier version does also mention same version box in the 4.2 S/C.
Post #638880 Tue Jan 16 2024 7:52pm
NoExpert
It’s the same with the 3.0TDV6/5.0SC 6HP28 trans, they’ve been upgraded in the same way, but you get the better 6HP28 that resolved a lot of the 6HP26 problems and has a higher nominal torque value. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #638882 Tue Jan 16 2024 10:20pm
