![]() | Home > Technical > Urgent help please |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
![]() ![]() Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
The CTEC is connected to the terminals under the bonnet not direct to the battery. |
Yes I’m definitely getting a new battery fitted. Just deciding when and where to take it or get a mobile fitter to fit it. Halfords s and AA will fit at home but RAC will not fit it only supply |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
If your not an AA member,
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 544 ![]() |
Save yourself a fortune and buy one on line from Tayna. Then fit it yourself.. super super simple… |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Easy but what about the coding? 2012 SDV6 - it's missing a couple of cylinders
Yes they do but you get a good discount when you are a member around £30 cheaper |
Yep I would do that but couldn’t do the coding bit |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Far more than Halfrauds Mobile when I checked them. 2006 RRS 2.7 HSE. |
