Home > Technical > Urgent help please |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Another win here! Actually two wins in a row, as the L319 is a 2005. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Fri Sep 08 2023 8:52am |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 457 |
The CTEC is connected to the terminals under the bonnet not direct to the battery. |
Fri Sep 08 2023 5:45pm |
Yes I’m definitely getting a new battery fitted. Just deciding when and where to take it or get a mobile fitter to fit it. Halfords s and AA will fit at home but RAC will not fit it only supply |
Fri Sep 08 2023 5:49pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
If your not an AA member,
Fri Sep 08 2023 6:22pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 535 |
Save yourself a fortune and buy one on line from Tayna. Then fit it yourself.. super super simple… |
Fri Sep 08 2023 7:33pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Easy but what about the coding? 2012 SDV6 - it's missing a couple of cylinders
Fri Sep 08 2023 10:51pm |
Yes they do but you get a good discount when you are a member around £30 cheaper |
Sat Sep 09 2023 7:27am |
Yep I would do that but couldn’t do the coding bit |
Sat Sep 09 2023 7:28am |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 |
Far more than Halfrauds Mobile when I checked them. 2006 RRS 2.7 HSE. |
Sat Sep 09 2023 4:54pm |
