![]() | Home > General (L494) > All Season Tyres for SVR? |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 243 ![]() ![]() |
295/40R22
LR_NUT Member Since: 03 Jan 2023 Location: Scotland Posts: 27 ![]() ![]() |
Jjvd21 the Pirelli’s are summer tyres and the pilot sports only go up 21 |
They must be labeled differently in Euro, here they are available up to 22” 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9022 ![]() ![]() ![]() |
The Asimmetrico doesn't appear on Pirelli's UK web site any more so possibly isn't going to around long in the UK anyway, if one can source some. ITSR Pirelli called it all season but it's pretty sketchy as one, I think.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
I bought a second set of wheels for the winter with 275/45/21s on. PITA to swap though.
PITA because of the weight/bulk? 2012 SDV6 - it's missing a couple of cylinders
I’ve been running 285/45R22 for 2 years without issue. Benefits: slightly softer ride due to taller sidewall, more choices in that size, less expensive in that size. Downsides: feather rub on full turn lock when the tires were brand new, now that they have worn it doesn’t happen anymore.
The height the car needs to be raised (use a couple of trolley jacks normally as the scissor lift in the garage has a car parked over it) and the weight of the wheels (difficult for weakling-me to remove without touching any part of the brakes). When doing, though, does give the opportunity to clean wheels and calibers properly.
