Home > General > Park heater gizmo |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
eBay Item No. 124117320536. EBay item number
Fri Jan 13 2023 12:01pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Yes to our D3 and its very good as long as your fbh actually works as it should in normal conditions. |
Fri Jan 13 2023 5:11pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5006 |
Follow links
Fri Jan 13 2023 8:08pm |
Ah, brilliant. Thanks.
Sat Jan 14 2023 3:12pm |
Not built in.
Sat Jan 14 2023 3:55pm |
OK, thanks bud. I'll try the fit tomorrow. |
Sat Jan 14 2023 3:57pm |
Tried fitting the gizmo. Worked then stopped. I've been told to cut the 2 yellow wires on the burner. 😱
Tue Jan 17 2023 10:33pm |
If the fitting instructions that come with it then cut it, it's an improved version of mine looking at it.
Tue Jan 17 2023 10:48pm |
Oh They want you to cut the CAN bus wires. This will stop the car turning the heater on. Personally I wouldn’t.
Wed Jan 18 2023 6:52am |
If unlocking the car is upsetting the heater :
Wed Jan 18 2023 7:12am |
Leaving the canbus untouched. I don't have screen climate as mines a 2008.
Fri Jan 20 2023 8:09pm |
